The Saab Link Forums - View Single Post - Broken Tensioner Problem Solved
Old 12-16-2014, 06:57 PM   #2
Drew in Houston
Drew in Houston's Avatar
Another way is to use a pipe wrench around the back of the assembly and pull forward like normal.
...it's better not to push the wrong way and break it though in the first place
Drew in Houston is offline   Reply With Quote
