The Saab Link Forums - View Single Post - El Diablo Possessed Me
Old 11-11-2014, 09:16 PM   #1
Cm452
El Diablo cutting heads for a Sawzall that is...
Transmission bushing NO CUTTING how-to - SaabCentral Forums
Attempted this job and after hours of beating the shit out of the slide hammer, including with a weird sling system, as well as a slingshot system with a crapload of bungee chords, I gave in and loaded up a Sawzall El Diablo metal cutting blades to got that effing bushing out...worked well, too well. I ended up cutting the actual bearing race about 1mm deep near the inside, tapering off to a surface graze near the outside. I then pressed in the new bushing over it.
Will this structurally compromise the bearing to the point where it is dangerous?
How bad did I screw it up?
Thanks,
Cm
BTW, it made a HUGGGE difference in play in the front axle...nice-n-tight now.
Cm452 is offline   Reply With Quote
