The Saab Link Forums - View Single Post - CIS problem
Thread: CIS problem
Old 01-22-2007, 08:16 PM   #3
saabsbreakdown
saabsbreakdown's Avatar
Send a message via AIM to saabsbreakdown
There are no points because its a hall effect electronic ignition.
The distributor has not been out of the car.
The cam is not a tooth off.
Thanks for the ideas though! DeLorean suggested I try and run it with the exhaust off, as it may be clogged. I removed the exhaust the other day but haven't started it yet. If it's not that, it probably is an ignition issue.
Car 178 - 1975 Saab 99 EMS
saabsbreakdown is offline   Reply With Quote
