The Saab Link Forums - View Single Post - oil light occasionally at idle, at first drive of day
Old 09-15-2014, 05:36 PM   #4
DrewP
DrewP's Avatar
If you get 20 or so psi at the adapter at idle I'd try replacing your oil pressure switch and drop the pan and clean the screen and pressure bypass to be sure.
The stock sender should turn the light on at about 6 psi. Your sender might just be coming on too early.
DrewP is offline   Reply With Quote
