The Saab Link Forums - View Single Post - Having Trouble Getting the Viggen Started After the Rebuild
Old 08-11-2014, 01:23 PM   #3
rl0089
Originally Posted by srp View Post
Is the tach jumping when you crank?
Have you tested the DIC?
Do you hear the fuel pump prime if you turn the key to run and don't crank it?
Tach does not budge when attempting to start. What would that mean?
The DIC should be good, its brand new, but I'll check it tomorrow.
I try to listen for the fuel pump but I have that annoying acc fan making too much noise to hear anything. Something else behind the dash is also making an on and off buzzing noise that goes away with when the key goes to off. And the little fan never shuts off even after the key is out! But thats another issue! Just trying to get it started!
rl0089 is offline   Reply With Quote
