The Saab Link Forums - View Single Post - My 94 SE Turbo Build/Bring Back To Better Condition Thread.
Old 01-27-2014, 05:47 PM   #13
hondafanatic17
hondafanatic17's Avatar
Okay so I changed my oil today, drained it into a clean pan and then filtered it as I was dumping it into the used oil drum and it didn't have any metal flakes in it, just some dirt and it was very thick. Didnt get time to removed the valve cover to see if anythings going on at the top end but it sound like its right under the valve cover closer to the passenger side. Got busy with trying to fix my reverse. I'm trying to figure out if it's the linkage or the actual reverse gear. I adjusted it a bit so that it goes into the reverse gear easier and I can now pull the key out with less pressure on the shifter then before. I used to have to put all my weight into it.
So now it's pull the valve cover off tomorrow and figure out reverse. Had anyone had their actual reverse gear take a crap before?
-Tim
1996 9000 CS-Daily Grind
1993 9000 CDE-Classy Lawn Ornament
hondafanatic17 is offline   Reply With Quote
