The Saab Link Forums - View Single Post - Please Help!: Won't start after replacing turbo
Old 11-14-2013, 04:08 AM   #6
tapper
Send a message via AIM to tapper
Only thing that'd cause no starts is if one of your air ducts is loose.... check the seals/clamps on everything including the intercooler end you think you may not have touched there's gotta be a leak... make sure the big hoses are as far as they go and super duper freakin tight-----
If you installed it properly you should have done the priming procedure that involves disabling fuel and cranking it over half a min.... did you do this this and remember to replace relays/fuses??
tapper is offline   Reply With Quote
