automatic gearbox problem
I have a 2002 Saab 9-3 Arc. While doing an oil change at a local service station I requested they change transmission fluid. Afterwards, no 3rd gear. I read a post on Saab Central where a person had the same problem because the shop put the new fluid in the wrong spot. They put it in through a bolt at the top, not through where the dip stick is. When they unscrewed the top bolt it moved a spring loaded sleeve type thing for third gear. I think the same thing happened to our car
Is there any information if this is correct and how to fix it
