The Saab Link Forums - View Single Post - T5 bpc Conversion Kit users?? (Newton Systems LLC by BobS)
Old 07-18-2013, 08:29 AM   #14
Marquer
Hi TTH,
Thanks for the reply and pic on the wiring! I have the Maptun stg.1 already for the automatic gearbox and as such I don't want to alter the software map...just reflash it the way it's needed for T7 adaptation, nothing else should be changed. I live down in Hungary and although we have one or two known trionic guys inside our Saab circles they only deal with t7, self-declared. And if it wasn't enough, I'm also concerned with the picky h/w modification. Although I now see the T7 route could be the best path, with a good and cheap valve plus no need to get an item through from overseas. Maybe I'll try to pull things together sometime for that mod, being it the cheapest, most tried and direct solution.
- '99 9-3 2.0 LPT auto hatchback Viggen'ed Maptun Stg.1 96k miles
- '95 NG900 2.3 N/A Coupe manual 131k miles
Marquer is offline   Reply With Quote
