The Saab Link Forums - View Single Post - Maptun problems: (EDIT: Maptun comes through!)
Old 06-29-2004, 12:32 PM   #10
abdukted1456
Trollerator
abdukted1456's Avatar
Originally Posted by ERP
My guess is the BPC solenoid is not functioning correctly. You should try swapping in another one. Or to just make your Saab more drivable connect the boost pressure hose directly to the wastegate. .
ERP, is that Ok to do for a T-7? (re wiring the hoses like that?)
If I only had a Saab buddy nearby to me who cold help me with this and let me borrow some parts for a test run.... I gotta now go hunting for parts I may or may not need, just to try this out? Man, this is turning into such a freaking project! this is just my luck.
You will only get base boost but you wont have to worry about fuel cut.
sorry, I am still a turbo newbie. What does that mean, that bascially the chip will not really be increasing boost? twhy not just go back to stock ECU?
Question; at 50% throttle do you only hit mid boost pressures or will it spike to fuel cut? I do not think that plugs or the DI is causing the problem.
at lower than full throttle the car seemed to drive just fine.
[/quote]
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline   Reply With Quote
