The Saab Link Forums - View Single Post - $2300 on NG 900 SE for power, were to start? -=Tweak=-
Old 05-30-2004, 07:59 AM   #4
Tweek's Turbos
Honestly, The T25-T28 rebuild is good if you are budget minded. Don't forget that if you drop extra money on a GtBB turbo, then you are taking money away from something that could possibly support that turbo's role. IE if you dont get a downpipe, how is that extra turbo going to perform.
My opinion on suspension b4 you do all the springs and shocks, is to do the front and rear sway bars, and poly bushings. I plan on installing the Abbott rear axle, at the same time as my springs and shocks too.
If I had to break it down with what you descriped it would be this.
New Stage 4 ECU after core refund:
-$535
GT28R Turbo
-750
JT downpipe without cat
-$340
Spearco Intercooler
-$250
Intake and Filter
-$100
Custom dual exhaust:
-$250
This sort of brings us to the end of the $2300, with maybe enough left over for springs. Seems like a healthy start, but I would definately add some items to it. What do you have ready to go, or on the car already?
Tweek's Turbos is offline   Reply With Quote
