The Saab Link Forums - View Single Post - Oil Change Question
Old 04-06-2006, 05:57 PM   #6
mike saunders
Yep...about 4 quarts, plus a little more for the filter. After you're done, run the car for a bit, then shut it off and let the oil drain back into the pan. Wait a few minutes and check it again. You'll probably need to add a touch more.
...and just be careful with the drain plug. Make sure to use a 6-point 13mm socket, not a 12-point, because you don't want to round it off.
good luck!
mike saunders is offline   Reply With Quote
