forge recirc valve question - The Saab Link Forums
Old 12-03-2012, 03:39 PM   #1
redviggen's Avatar
I just installed a forge recirc valve on my viggen it sounds nice however it sounds like the spring is "bouncing" when Ilet off the gas otherwise it seems like it is holding boost better
I am currently using the stock green spring which should be.ok for a viggen somewhere in the vicinity of stage 2 as I have been told anyway thanks for your input
redviggen is offline
Old 12-03-2012, 04:38 PM   #2
yllwJet's Avatar
thats normal. itll flutter if you let off the throttle slightly. let off completely and it will discharge the pressure side in one shot
yllwJet is offline
Old 12-03-2012, 05:57 PM   #3
redviggen's Avatar
That's what I thought thanks pat
Old 12-04-2012, 06:37 AM   #4
yllwJet's Avatar
no problem
yllwJet is offline
Old 12-04-2012, 07:47 AM   #5
Wagon Shaggin'
Saabeh's Avatar
Put the lightest spring in the valve. Perhaps in yllwjets mondo-pressure car it flutters a bit, but in most cases it shouldn't.
Saabeh is offline
Old 12-04-2012, 02:21 PM   #6
redviggen's Avatar
I didn't change out the springs used the stock (green) spring . I was thinking that maybe it need a spacer to compensate but maybe I'm thinking wrong . I know mike d tuned it to an aggressive stage 2 but I can't imagine needing to go up to a heavier spring if Nick T runs the same spring on his viggen which puts out a hell of a lot more power than I do.
Old 12-04-2012, 03:55 PM   #7
yllwJet's Avatar
i only ran this valve with the stock turbo setup. it doenst flutter under accelaration but only when you slightly let of the gas it will flutter because there isnt enough vacuum to open the valve 100%. only when you let off the pedal completely will it open 100% with the required vacuum to open it.
yllwJet is offline
Old 12-05-2012, 06:33 AM   #8
Wagon Shaggin'
Saabeh's Avatar
This has never happened to any of my T7 cars ever. I can go full throttle and let of super slow with NO flutter.
Not sure if you or the OP had that dumb distribution valve still connected either: T7 Turbo Bypass Valve Mods – TrollTuner
Also, did you buy the valve used?
Saabeh is offline
Old 12-05-2012, 07:42 AM   #9
PimpMyPc's Avatar
I can get some pretty bad flutter on T5 if I let off slowly/just right with my forge, but I have to be really trying to get it to do it. Freshly greased too.
PimpMyPc is offline
Old 12-05-2012, 07:48 AM   #10
Marks9-3's Avatar
My Forge flutters after slowly letting up after being under mild load. Freshly greased and everything, would still do it. My ng900 did it (different Forge valve), and my 9-3 did it with the t25 stg3 and still with the 19t.
Marks9-3 is offline
Old 12-05-2012, 09:03 AM   #11
redviggen's Avatar
I did the bypass valve mod recently when I redid my vacuum lines, the weird thing is, I notice the flutter when I get off the gas totally, I just installed the valve like it was out of the box. I guess my question was would I get less flutter if I add a spacer or is it normal, It doesn't seem as if anything is wrong I just wanted to make sure it was operating normally. This is my fist turbo car somethings are a little foreign to me, so I thought I would ask you all. If I would have got a response to the effect "DON'T DO THAT YOU WILL BLOW UP YOUR ENGINE" that would have been a key indicator I was headed down the wrong path. It sounds like I'm ok though.
Old 12-05-2012, 09:33 AM   #12
PimpMyPc's Avatar
If you add a spacer, you'll increase the pressure needed to open the piston which will cause it to flutter worse.
PimpMyPc is offline
Old 12-05-2012, 10:40 AM   #13
redviggen's Avatar
i wasnt sure exactly how that worked, thanks for the info,that being said when you start running higher boost pressures ie bigger turbo forged pistons etc. it will actually flutter less because more pressure is acting against the spring??
Old 12-05-2012, 11:07 AM   #14
Jaws's Avatar
This depends upon how you have the Forge valve mounted.
I had the opposite problem where my Forge valve opened too quickly and stayed open when accelerating under partial throttle. This was only evident when running it as a BOV (T5) - you could hear the BOV releasing when accelerating under partial throttle.
I run the blue spring now with one shim to keep it closed under these vacuum conditions. I also run the valve backwards with the air pressure directly against the spring versus against the side of the valve. I don't get flutter and it holds all 28 PSI. My Forge valve would leak air when I ran it with the air pressure against the side of the valve.
Jaws is offline
Old 12-05-2012, 02:44 PM   #15
redviggen's Avatar
I didn't think a recirc valve could get this complicated maybe ill try mounting it backwards and see if it still flutters if it does I guess that's the way it is supposed to be
Old 12-05-2012, 05:33 PM   #16
yllwJet's Avatar
the little vaccum line port should be facing your battery
yllwJet is offline
Old 12-05-2012, 10:57 PM   #17
bogan's Avatar
I bet the noise is a bit of compressor surge and not the BOV at all. My valve has never "fluttered" only a loud "WHOSH".
A bit a compressor surge wont hurt.
When I was tuning my forge I thought that I also had the "Green" spring installed. Turns out It was actually a "Blue" spring.It's a real shitty color blue too , almost A dark green.
So as it turned out my valve came standard with a blue spring. The green spring is very soft
P.S I run my Forge backwards aswell
bogan is offline
Old 12-06-2012, 10:30 AM   #18
lms
Hyperboost shorty, out of box, no extra springs which really are just for your shelf, done!
It's funny how many people buy this same valve, which works fine, but they still post about fluttering, spring types, etc. The hyperboost rocks!
lms is offline
Old 12-06-2012, 10:57 AM   #19
Wagon Shaggin'
Saabeh's Avatar
I took a crappy video of my car not surging after stabbing it and letting off slow. If anyone wants to see it, ill upload it. Kinda hard to hear.
Saabeh is offline
Old 12-06-2012, 04:25 PM   #20
redviggen's Avatar
I would be interested
Human Verification
