215-40-18 or 225-40-18? & which tires? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > Performance Modifications for the NG900 / Old 9-3
Old 02-17-2012, 10:13 AM   #1
gm
gm's Avatar
In the next week or two I need to pull the trigger & get some new shoes for my viggen. Present 17's are going to be winter only & it's just to difficult finding 17's that fit around my brakes.
Wheels are 18x7.5
Offset: +42mm
Backspacing: 5.90"
Bolt Pattern: 5-110
Rec. Tire Size:215/40-18
Weight: 20.8lbs.
Tirerack suggests 215's, but will 225's work w/o rubbing & possibly a occasional track day?
2K viggen 5dr with koni spring/shocks?
Considering these tires
Continental Extreme Contact DW @ $166 ea 340 tread, 92 load
Goodyear Eagle F1 Asymetric 2 $171 300 & 91
Michelin Pilot Sport PS2 $189 220 & 92 clearance
Leaning towards the PS2's
2000 viggen stage ?? with a 18t
2009 Buell 1125cr
gm is offline
Old 02-17-2012, 01:59 PM   #2
bogan's Avatar
Garage
I've got 225 x 17's and they are perfect. Guys even run 235's.
B.L.T.H....... Brake late Turn hard
bogan is offline
Old 02-17-2012, 03:27 PM   #3
I currently have hankook 215s which I got from tirerack.com. They are probably the best tires for the price. I got them for $128 each. Theyre crazy grippy but still seem to wear decent. They're also really good in heavy rain unlike most other tires I've have on my viggen. The only bad thing is they have a soft sidewall but I have 18's so its not bad. They're definitely worth a look.
Sent from my HTC Vision using AutoGuide.com App
danieljordanmaddux is offline
Old 02-17-2012, 06:40 PM   #4
gm
gm's Avatar
My present Dunlops I am less then impressed with. They are sticky.... but hold crap they get LOUD as they age!!!
I will check them out... trying to stay with a tire with a sidewall rating of 90+ to hopefully help minimize tramlining & all that crap
Any other opinions??
2009 Buell 1125cr
gm is offline
Old 02-17-2012, 06:44 PM   #5
Aero's Avatar
Send a message via AIM to Aero
Hankook Ventus V12 Evo 225/40/18
Great summer DD tires that will do well during light track duty.
Hankook Ventus V12 evo K110
Aero is offline
Old 02-18-2012, 02:26 AM   #6
These are the ones I was referring to
Old 02-20-2012, 06:30 PM   #7
gm
gm's Avatar
I think I am going to do either the Continental DW's at $161 or Michelin Pilot Super Sport at $225 minus a $70 rebate... so $210 ish each. Just not sure it's worth the extra $200 ish for Super Sports vs DW's.
2009 Buell 1125cr
gm is offline
Old 02-22-2012, 07:02 AM   #8
lowbudgethero's Avatar
You have the star specs too lol?
If I were you I would go with the Michelin Pilot Super Sports, Michelin always seem to last a lot longer than their treadware rating seems to indicate
lowbudgethero is offline
Old 02-22-2012, 11:05 AM   #9
Probably is worth the extra $200 down the line. I've never had a roundness problem with Mich tires, or a noise problem, I have with the Conti performance tires. The Mich Pilot also tend to last longer and actually meet their mileage rating.
See the reviews/surveys at tirerack. I'm not usually too excited about statistically invalid surveys, but with a few million miles reported, you have to figure that the average is moderately accurate.
BobSabbert is offline
Old 02-22-2012, 07:45 PM   #10
gm
gm's Avatar
Thanks again.... going to hit a couple local wheel/tire shops and see if they will beat tirerack's price. Some new Enkie wheels & Micheli rubber
Thanks for the input....
2009 Buell 1125cr
gm is offline
Old 02-24-2012, 02:42 PM   #11
gm
gm's Avatar
Went to local shop to try and compare them vs tirerack
same price on wheels.... $180 ea
not so close on tires (Michelin Pilot Super Sport 225-40)...... $286 ea vs $225 (plus $70 gift card)
Shipping is around $60 if I recall...... they wouldn't/couldn't move on the tire price or wheel price. Stated I have to pay shipping, mounting/balancing, rotation & alignment thus add around $500 to tireracks price to get equilevent to their's (Tire Discounters). Hopefully stop by Discount Tires tomorrow & see what they can do.
O yea.... sales guy told me I should use 235-35-18's on the car. I mentioned lack of tire room & he claimed not a issue... only two tires that he had available at that size, Continental Extreme Contact DWS $196 ea or BFG KDW NT $263 ea
2009 Buell 1125cr
gm is offline
Old 02-24-2012, 05:10 PM   #12
The 235/35 is closer to the stock diameter, almost exact. However, it's 10mm wider... might rub on full lock. The 235/35 is pretty short on sidewall height. If you are buying from that guy, get him to say they won't rub, then he can replace them if they do at no charge.
In the 40 series the 215 is almost exact. The 225 is .6" larger diameter... not too bad either and gets you a tiny bit more sidewall.
If you're going mail order, I'd go with the 225... but I'm a conservative guy.
Old 03-05-2012, 11:54 AM   #13
gm
gm's Avatar
New wheels/tires arrived.... so far so good! It's to cold & the tires are to new to push much in turns (34 degrees) but I will be able to push them a bit this week since it's suppose to be in the 50's-60's.
Mostly want to see if there is any rubbing which from the looks of it I should be fine.
I went with the Pilot Super Sports, impressed with the ride, thought it was going to be a lot stiffer but it isn't. Hopefully post some pics in the near future
2009 Buell 1125cr
gm is offline
Old 03-05-2012, 05:33 PM   #14
What size did you end up with?
FYI - my Pilots were pretty squirmy until I had a few hundred miles on them.
Old 03-05-2012, 08:36 PM   #15
gm
gm's Avatar
I went with 225-40-18's
I have been using Blizzac W60's since December for some stupid reason (it's been so warm, killed my snow tires) thus the S. Sports feel quite good!!! I did a easy 2nd gear roll on & they both just spun.... but I expected that
2009 Buell 1125cr
gm is offline
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
