| Register | Garage | Photo Gallery | FAQ | iSpy | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| Performance Modifications for the NG900 / Old 9-3 This forum contains PERFORMANCE related Q&A's for the NG900 and 9-3. This may also include suspension. |
LinkBack | Thread Tools |
#1 |
question about clocked turbo and wastegate linkage
so after i clocked my turbocharger, i noticed that now i need to do something about the wastegate actuator linkage, and also the mount, my idea was to only use 1 of the mounts out of (i think 3) and bend the linkage slightly so it would line up.
is this a good idea? the point of this post is to see how other people coped with a clocked td04-15t and how they mounted they're wastegate and how they bent (and how to bend) the wastegate linkage. pics would be sick, as i'm almost done with this swap, and i dont want to frig up my wastegate setup.
1997 900 se. STG3 td04 crossflow IC viggen clutch v2 dp gs shortshifter much other go fast parts! |
| Sponsored Links | |||
Advertisement | |||
#2 |
Should have just bolted up without clocking, unless you got a 6cm off of a 9000.
Where did you get this TD04? |
#3 |
well, i had to clock it due to my -6an 90* fittings i used, its off of a HOT 01 9-3.
#4 |
mine is clocked because i used to have a different IC setup. I had a flange welded on another part of the housing for the WG bracket. 3 years later still no problems.
#5 |
ended up putting together and it is fine.
| Sponsored Links | |
Advertisement | |
| Thread Tools | |
