How to remove the speed limiter without a tune!! - The Saab Link Forums
Old 05-10-2011, 11:41 PM   #1
900AERO's Avatar
So I met a Saab owner today. We started talking Saab's and at some point I was told that if you disconnect the waste gate hose from the boost control valve you would trick the speed limiter function in the ECU and allow for boost to stay on after 155mph and therefore reach a higher speed than 155. My answer was that by doing so you are risking blowing your engine. Then he said that it should be fine as long as you watch your boost gauge and back off the throttle if you hear knock. then I said that at speed like that you want to only focus on the road and not on your boost gauge and the knock sound or anything else.
Even-though I would NEVER pull that hose for any reason other than diagnostics of the turbo system is it true what he said?
Tuners? please advice.
WHATEVER.....SAAB'S ARE FASTER THAN WHAT YOU THINK.
900AERO is offline
Old 05-11-2011, 12:23 AM   #2
VWSAABVT's Avatar
no
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 05-11-2011, 02:28 AM   #3
Actually - it will work although completely ridiculous in practice. You will need to mystically feather the throttle to keep below the low fuel cut on the stock ECU and hope that's enough to push through 155mph.
You can also achieve similar results by dropping the car off a cliff.
faero is offline
Old 05-11-2011, 07:34 AM   #4
Green9kAERO's Avatar
Well, If you kill the speed signal and rig a MBC on there, you might be able to do it! Its still a waste of time.
Also, Trionic senses knock before you do, and with these girly b2x5 engines, I don't think I'd want to be relying on my sense of hearing!
Green9kAERO is offline
Old 05-11-2011, 07:41 AM   #5
I lol'd
If we were super dorks we could figure out whether this was true using the rule of terminal velocity. I'm curious if it would fall faster or slower than 155mph.
Topher is offline
Old 05-11-2011, 07:58 AM   #6
Deez Nutz
Palmer's Avatar
I would not talk to that guy about cars anymore.
TDi/JKU/330i
Palmer is offline
Old 05-11-2011, 07:58 AM   #7
Lendo's Avatar
Make sure you have old, rotted, tires on the car.
That's all the tuning advice I have for today.
Lendo is offline
Old 05-11-2011, 08:17 AM   #8
Wagon Shaggin'
Saabeh's Avatar
+1
Probably similar type of person who talks about putting brakes on "backwards."
Saabeh is offline
Old 05-11-2011, 08:19 AM   #9
BurnsSide42's Avatar
I got one for you - pinch off all your brake lines if you want to go faster. It's just that simple. ***
(Seriously - don't do that, but if you do - you will just be proving Darwin's Theory and helping solve the worlds population problem - and I am not accountable for your actions or anything you say or do otherwise)
Original TSL Founding Member
Check out
for your repair needs
BurnsSide42 is offline
Old 05-11-2011, 08:26 AM   #10
Stupid fine print! your discouraging potential candidates!
Old 05-11-2011, 09:12 AM   #11
I think it would encourage them more.... when was the last time you didn't do something because you were told NOT to? lol
Check out
Old 05-11-2011, 09:43 AM   #12
b dash rian's Avatar
here's the thing...
5th gear makes 26 mph at 1000 rpm, iirc (its in the manual). that means that 6000 rpm will make 156 mph. so you'd be running damn close to redline on a stock tune.
food for thought, i suppose.
good luck....
b dash rian is offline
Old 05-11-2011, 03:04 PM   #13
lowbudgethero's Avatar
I couldn't find a long enough stretch of road to get to 155
140-145 was as close as i can get with a stage 3 tune
lowbudgethero is offline
Old 05-11-2011, 07:08 PM   #14
Greek Mod
grkguy89's Avatar
cut your floor boards out
then go test your theory about the limiter
if your brakes dont slow you down as quickly as you would like
just hit your feet against the ground (think Flintstones) to help with the braking/breaking
best performance advice i can give you
Current Activity: Moderating
grkguy89 is offline
Old 05-11-2011, 07:32 PM   #15
turbo900se's Avatar
well with my flux capacitor installed i've never had to go over 88mph... so going over 155 is out of the question
turbo900se is offline
Old 05-11-2011, 10:28 PM   #16
Supergreensol's Avatar
Can we sticky this thread please? I'm on the ground laughing right now.
'95 900se Vert Black on Black...RIP
"If you pull the pan and find anything other than what I described, I'll eat a pile of hammers." ~spgproject
Supergreensol is offline
Old 05-11-2011, 10:44 PM   #17
900AERO's Avatar
900AERO is offline
Old 05-11-2011, 11:31 PM   #18
Snabb SAAB's Avatar
Two words... booster rockets.
Current SAABs: 2000 9-5 Aero SC - 1987 900i 8v Past SAAB: 1995 900 SE Turbo
Snabb SAAB is offline
Old 05-12-2011, 10:16 AM   #19
comtrang's Avatar
Don't see why anyone would want the speed limiter removed on a stock-ish car, anyway.. it would take forever to reach 155mph with it, which is dangerous. There is some truth in saying that high hp cars are safer because they can get to whatever reckless speed the driver's trying to get to, faster, and then stop. It'd probably take a minute just from 100mph to get there and I don't know about you guys but flooring my car for that long just scares me.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 05-12-2011, 11:12 AM   #20
132417SAAB's Avatar
this; took me eons to get to 135 on my stock 97 900 taking all the fun out of it
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Tags
herping and derping
Human Verification
