custom exhaust... Muffler? - The Saab Link Forums
Old 03-21-2008, 07:08 PM   #1
classifiedsaab9000's Avatar
hey I have a 3" genuinesaab downpipe for my 9000 with a race cat... im getting my mechanic to fully make a custom catback from the catalytic converter... im curious whats the best type of universal 3" muffler i can use for my custom exhaust? thanks guys.
classifiedsaab9000 is offline
Old 03-21-2008, 07:10 PM   #2
Aero's Avatar
Send a message via AIM to Aero
Magnaflow! Straight through design, sound awesome, and are reasonably priced.
Whatever you do, DO NOT go with a Flowmaster. The "chambered" design is not good for a turbo car.
Aero is offline
Old 03-21-2008, 07:14 PM   #3
Aero can you send me a picture so i have a rough idea as to what to shop for? i appreciate it thank you.
Old 03-21-2008, 07:22 PM   #4
HIDSPG's Avatar
Thats what I have on my SPG. Flowmaster 40 series. I see no problems with it.
88 SPG, 08 TX Combi
HIDSPG is offline
Old 03-21-2008, 08:57 PM   #5
aerodyte's Avatar
I like this high flow cat design personally:
http://www.egansworld.com/oldsite/VDP.html
Aerodyte-Barry
96' 9k Aero Stage 6 Full Aerodyte Performance Mods (GT3071wg, 630cc inj, 50mm IC, t5Suite)
aerodyte is offline
Old 03-21-2008, 10:55 PM   #6
Deez Nutz
Palmer's Avatar
No problem with flowmaster:
TDi/JKU/330i
Palmer is offline
Old 03-21-2008, 11:04 PM   #7
Cpenning623's Avatar
Send a message via AIM to Cpenning623
I have a magnaflow 6" round muffler. Its very poppy and burbly. An oval muffler will give you a smoother purr rather than an aggresive pop and snarl. A flowmaster gives you that pulsey sound. They all are pretty much free flowing straight through designs, it just depends on what sound youre after.
Cpenning623 is offline
Old 03-21-2008, 11:45 PM   #8
aeroboost's Avatar
do you guys remove the muffler right before the rear axel?
aeroboost is offline
Old 03-22-2008, 01:18 AM   #9
Aero's Avatar
A chambered muffler adds unnecessary backpressure on a turbo vehicle.
This was posted on www.fullsizechevy.com which is a truck forum. Supposedly this review was performed by Martel Brothers...
All tests via an independent lab
All tests @ 15” wc
2 “ Straight Pipe 283 CFM
2 “ Straight Pipe 365 CFM
2 “ Straight Pipe 521 CFM
2 ” Typical Bent tailpipe 268 CFM
2 ” Typical Bent Tailpipe 417 CFM
2 ” Inlet/Outlet_ Glass Pack Tips- No Louvers- Smooth 274 CFM
2 ” Inlet/Outlet- Glass Pack Tips-Louvered 133 CFM
Same as above set for reverse flow 141 CFM
2 ” Cherry Bomb 239 CFM
2 ” Cherry Bomb 294 CFM
2 ” Inlet/Outlet Dynomax Super Turbo 278 CFM
2 ” Inlet/Outlet Ultraflow Bullet 512 CFM
2 ” Inlet/Outlet Gibson Superflow 267 CFM
2 ” Inlet/Outlet Flowmaster ( 2 Chamber) 249 CFM
2 ” Inlet Outlet Flowmaster ( 3 Chamber) 229 CFM
2 ” Inlet/Outlet Thrush CVX 260 CFM
2 ” Inlet/Outlet Maremount Cherry Bomb 298 CFM
2 ” Inlet/Outlet Hooker Aero Chamber 324 CFM
2 ” Inlet/Outlet Hooker Max Flow 521 CFM
2 ” Inlet/Outlet Borla Turbo 373 CFM
2 1/2" Inlet/Outlet Magnaflow 284 CFM
Standard OEM 2 ” Inlet/Outlet 138-152 CFM
Standard OEM 2 ” Inlet/Outlet 161-197 CFM
The madrel bending of the pipes done by aftermarket exhaust companies is good for 2-4 h.p. depending on the severity of the stock bends. Most local exhaust places dont have a mandrel bender so changing the pipes out doesnt do anything if pipe size it not increased.
My opinion, if its more noise and a little more power just add the best flowing stainless muffler to the current system and never do it again. If you increase pipe sizes, then a local shop and only stainless. Dont care about money but want ease and better gains than most local shops can offer with no pipe size increase, and aftermarket exhaust.
NOISE does not mean power, some think it does is why Flowmasters are sold in the numbers they are!!!
and
Thought I would add this review too.
The results in HP order:
1.Flowtech Warlock (open) 374.2 hp/ 333.1 tq
2.Bassani Real Street 373.7 hp/ 333.8 tq
3.Hooker Maxflow 373.5 hp/ 333 tq
4.Borla XS 373.3 hp/ 332.6 tq
5.Magnaflow 372.8 / 332.5 tq
6.MAC 372.3 hp / 331.5 tq
7.Flowtech Afterburner 372.3 hp/ 330.1 tq
8.Hooker Aerochamber 372.1 hp/ 330.4 tq
9.Bassani 372 hp/ 333.5 tq
10.Spintech 371.6 hp/ 332.2 tq
11.Edelbrock Performer RPM 370.9 hp / 331.3 tq
12.Borla XR1 370 hp/ 334 tq
13.Flowtech Terminator 369.5 hp / 331.3 tq
14.Dynomax Ultra Flo 369.4 / 333.2 tq
15.Flowmaster 369.4 hp / 331.8 tq
16.Flowtech Warlock 366.3 hp / 325.3 tq
17.No muffs 365.2 hp / 330.1 tq
Sound Off in Quietest to Loudest (Decibels):
1.Borla XS, 80db at idle, 90db at 2,000 rpm, 110db at WOT.
2.Hooker Maxflow, 80db at idle, 90db at 2,000 rpm, 120db at WOT.
3.Magnaflow, 82db at idle, 91 at 2,000 rpm, 114db at WOT.
4.Flowmaster, 82db at idle, 93 at 2,000 rpm, 115db at WOT.
5.Flowtech Warlock, 83db at idle, 92 at 2,000 rpm, 112db at WOT.
6.Dynomax UltraFlo, 83db at idle, 94 at 2,000 rpm, 113db at WOT.
7.Borla XR1, 83db at idle, 96db at 2,000 rpm, 118db at WOT.
8.Bassani Street, 83db at idle, 96db at 2,000 rpm, 120db at WOT.
9.Edelbrock RPM, 84db at idle, 93db at 2,000 rpm, 118db at WOT.
10.Bassani Real Street, 84db at idle, 96db at 2,000 rpm, MAX. (120+db).
11.Flowtech Afterburner, 86db at idle, 94db at 2,000 rpm, 115db at WOT.
12.Flowtech Terminator, 86db at idle, 94db at 2,000 rpm, 119db at WOT.
13.Hooker Aerochamber, 87db at idle, 94db at 2,000 rpm, 114db at WOT.
14.SpinTech, 87db at idle, 97db at 2,000 rpm, 116db at WOT.
15.MAC, 87db at idle, 98db at 2,000 rpm, 119db at WOT.
16.No Muffler, 91db at idle, 103db at 2,000 rpm, MAX. (120+db).
http://forums.stangnet.com/archive/index.php/t-392314
and then
I found another flow test comparision.
http://www.svtoa.org/articles_006.htm
MODEL
Flow Rate Muffler Inlet Size
@ 20.3" H2O
+ Edelbrock 5501 492 scfm 2.25"
$ Flowmaster 42440 483 scfm 2.25"
Race Magnum Welded 17216 711 scfm 2.25"
+ Edelbrock 5511 579 scfm 2.50"
$ Flowmaster 42540 352 scfm 2.50"
Ultra-Flo SS 17263 1133 scfm 2.50"
Race Magnum Welded 17218 1000 scfm 2.50"
# Borla 40600 836 scfm 2.50"
+ Edelbrock 5505 708 scfm 3.00"
$ Flowmaster 43040 392 scfm 3.00"
Ultra-Flo SS 17296 2200 scfm 3.00"
Race Magnum Welded 17220 2200 scfm 3.00"
# Borla 40450 1400 scfm 3.00"
# Borla 40575 1100 scfm 3.00"
@ Edelbrock 5535 562 scfm 3.50"
$ Flowmaster 435409 576 scfm 3.50"
Ultra-Flo SS 17268 2200 scfm 3.50"
Race Magnum Welded 17224 2200 scfm 3.50"
# Borla 40615 854 scfm 3.50"
@ Edelbrock 5537 1400 scfm 4.00"
* Flowmaster 54040-10 634 scfm 4.00"
Race Magnum Welded 17225 2600 scfm 4.00"
# Borla 40741 1450 scfm 4.00"
+ Edelbrock General Application Series
@ Edelbrock Victor Series Race
$ Flowmaster 40 Series ( 2 Chamber)
* Flowmaster Delta Force Race Series
# Borla XR-1 Racing Series (Round or Oval)
Aero is offline
Old 03-22-2008, 01:22 AM   #10
Aero's Avatar
On my Aero, I ran a 3" downpipe, catless, to this muffler.
http://store.summitracing.com/partde...5&autoview=sku
It sounded great and was not too loud. No drone on the highway however it had some "bark" when I stepped on it. If I was building another exhaust for a turbo vehicle, I'd go with a Magnaflow for sure.
Last edited by Aero; 03-22-2008 at 01:26 AM. Reason: Chambered muffler on a turbo ride = muzzle
Aero is offline
Old 03-22-2008, 11:47 AM   #11
Green9kAERO's Avatar
i do know that in maine if you are required to get your car decibel tested, it is done at 3800 RPMS (3/4 of peak hp RPM) and my car was about 10 decibles above the 95 db limit.... which is bullshit because my car isnt loud compared to, just about every truck in the town...
JP
Green9kAERO is offline
Human Verification
