is this mod the real deal or just bs ???? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Performance Modifications for the 9-5
Old 03-03-2011, 03:43 PM   #1
pete93t's Avatar
Send a message via AIM to pete93t Send a message via Yahoo to pete93t
Question is this mod the real deal or just bs ????
stumbled across this today just wanted some input if this is a good idea or not ?? hmmmm
Saab-Tuners.com ][ Trionic 7 turbo faster response modification
-05 9-5 aero (BOOST2)-
-1980 900 Holset t5 monster-
pete93t is offline
Old 03-03-2011, 03:55 PM   #2
saabkid37's Avatar
nick posted about it bout 2 years ago. ive been running like that for about a year.
T7 Turbo Bypass Valve Mods – TrollTuner
saabkid37 is offline
Old 03-03-2011, 03:58 PM   #3
pete93t's Avatar
can you tell a difference ? and the car still runs fine do idol problems ect ?
pete93t is offline
Old 03-03-2011, 04:20 PM   #4
saabkid37's Avatar
yes and yes
Old 03-03-2011, 04:30 PM   #5
pete93t's Avatar
sweet ill try it out at some point
thanks for the info
pete93t is offline
Old 03-03-2011, 04:32 PM   #6
User
zingZACH's Avatar
What are the main differences you notice? It really doesn't go into detail about the benefits. Do you unplug the valve on the firewall? Also, you hook the boost gauge up to the bpv hose? I thought this was a no-no on T7.
No-no
T-7 boost gauge install.
You CANNOT have a BlowOffValve on T-7 because T-7 "reads and needs" all the air that passes through the motor. If some of the leftover air goes out a BOV for the "PSSHT" noise T-7 will miss this. It's called "metered air". If there is too little "metered air", T-7 will freak out, and give you a CHECK ENGINE LIGHT.
But Yes from Nick?
http://trolltuner.com/?p=219
NickT says:
30.11.09 at 12:49
Boost gauge must see manifold pressure/ vacuum to give you good data. T into the Bypass valve is the best idea.
You do not want to T into the MAP sensor or fuel regulator hoses. A failure of either of these signals will lead to engine damage at full boost.
On a t7 car there are rare times when you could see more pressure in front of the throttle. There is no vacuum on the intake pipe either. -N
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-03-2011, 04:35 PM   #7
saabkid37's Avatar
read nicks page.
boost gauge on bpv line +solenoid, and i could watch the hesitation in letting boost out when letting off the gas, as well as the late response to getting on it.
Old 03-03-2011, 04:40 PM   #8
User
zingZACH's Avatar
Good to know.
zingZACH is offline
Old 03-03-2011, 04:53 PM   #9
saabkid37's Avatar
You quoted the bov part.
The issue with T-7 and tapping the line to the BPV itself is that it will not read properly. There is a system that controls what the BPV sees, and you want to tap into the system that controls the BPV.
Thats what you would normally worry about, but that system is the solenoid your bypassing. Regardless, the system is a noise reducer to make the car more "civil" anyway so you can t off the bov line regardless anyway, you may just get weird delays/responses like I did.
Bypass the solenoid and you get a line straight off the manifold to both the gauge and valve so both react to real manifold pressure
Old 03-03-2011, 05:11 PM   #10
User
zingZACH's Avatar
Nice, I'll have to do that to the Vig.
zingZACH is offline
Old 03-03-2011, 05:19 PM   #11
2legit2quit's Avatar
Send a message via AIM to 2legit2quit
im confused. will this get rid of hanging revs?
Stage 3 manual 9-3 se
Hell yeah. All the FWD caddys have roll races like all damn day. Then the cruise over to 'Luca's house for some hard parking and body work tips.
2legit2quit is offline
Old 03-03-2011, 05:30 PM   #12
saabkid37's Avatar
boost related mod only.
Old 03-03-2011, 05:37 PM   #13
hold boost better oh wuhhh?
Old 03-03-2011, 05:44 PM   #14
pete93t's Avatar
i'm sure it holds boost the same its just a much shorter route when your running the direct line vs. having it flow through the vac valve. i get what your saying
pete93t is offline
Old 03-03-2011, 06:10 PM   #15
saabkid37's Avatar
length of routing doesnt matter (within reason)
the solenoid is ecu controlled to make the bpv not "whoosh" at lower boost levels by controlling the pressure applied to it.
Old 03-03-2011, 06:11 PM   #16
pete93t's Avatar
gotcha
pete93t is offline
Old 03-04-2011, 05:11 AM   #17
Ice Man's Avatar
Easy enough to try. I would welcome a bit better throttle response.
Ice Man is offline
Old 03-04-2011, 09:57 AM   #18
Anyone know if this would work with T8? ...i could use some better response too.
AutoXer01 is offline
Old 03-04-2011, 05:53 PM   #19
Paul Campagna's Avatar
I tried this on the Vig and got a check engine light. Back to normal, CEL gone... Didn't notice a difference, but can't drive with a CEL...
Paul Campagna is offline
Old 03-04-2011, 08:46 PM   #20
saabkid37's Avatar
if you got a cel you did it wrong.
dont unplug the solenoid.
Human Verification
