Upgrading brakes on an '06-09 9-5 - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Performance Modifications for the 9-5
Old 08-24-2016, 02:18 PM   #1
I want to get parts together for upgrading my brakes later this year or early next.
I don't want to spend $3k for some extravagant aftermarket stuff.
Here is what I am thinking:
06+ 9-3SS Aero calipers and 314mm rotors
Please help me confirm, this is a 100% direct bolt on, but I require the 9-3SS brake lines. That's an excuse to upgrade to the brake lines. For pads I am thinking Hawk Ceramics. Do I also need to modify the dust shield?
I am thinking I can get this done for under $500 though I may need used calipers to do it at that price.
Now for the rear, looks like they got rid of the 300mm rear setup on the '06+ cars. So I figure I will do that setup which I once did on the Viggen with a GS kit. Is there another option, is the 06+ 9-3SS another option or improvement over the 300mm setup?
TIA
Jameson is offline
Old 08-24-2016, 04:58 PM   #2
Cark's Avatar
You're running 18's so there is always the Cobalt SS/Brembo option? I know Tweak and some others had done the upgrade, and I feel like it can be had for ~$1000 or so. Just something else to consider. The 300mm vented setup in the rear is a no brainer.
02 9-5 Linear turned Aero, 5spd S/C
85 900 turbo - T5ed (in a day)
Cark is offline
Old 08-24-2016, 05:04 PM   #3
Yes, 18s.
Hmm, Brembos would be nice, a real upgrade to the SS? Maybe someone will chime in with what's involved.
Jameson is offline
Old 08-24-2016, 05:06 PM   #4
Cark's Avatar
Tweak had a thread over on SC, maybe a few posts about it here too? His setup looked nasty! (in a good way)
Cark is offline
Old 08-24-2016, 05:11 PM   #5
4piston, yum. ZZP has new sets with ceramic pads for $399 on eBay.
Jameson is offline
Old 08-24-2016, 05:13 PM   #6
Cark's Avatar
Yup!!! I always wanted to do the brembo's, but could never get away with 18's in NH. I actually just "downgraded" to 16" RK1's that I plan to run year round with some all weather Nokian WRG3's
And here it is in case you didn't find it already...
Big Brembos, Tiny Budget.
Cark is offline
Old 08-24-2016, 05:21 PM   #7
Thanks, I got lazy and hit Ben up on FB.
Jameson is offline
Old 08-25-2016, 04:54 PM   #8
srp
srp's Avatar
Send a message via AIM to srp
I have all but the rotors (and spacers) for putting Brembo's on my 9-5. Just waiting for the damn Hawk HP pads and cryo rotors to show some signs of wear...
Besides the calipers, pads and pins, you need...
Custom cut rotors(lots of controversy around rotors):
Brembo Kit 315mm Sport Rotors Pair (For Saab), GenuineSaab.com
Mounting Bolts(be careful with recommendations as the NG9-3 uses different length bolts then the 9-5)
M12 x 1.75 x 40 MM Class: 10.9 Flanged/Automotive
Bushings:
http://www.mcmaster.com/nav/enter.as...6&pagenum=1120
And I believe extended brake lines. But there are lots of arguments around that as well.
srp is offline
Old 08-25-2016, 04:55 PM   #9
srp
srp's Avatar
Lot's of good threads posts from "qwikredline" on SC.
FYI, he may also be a good resource for the LSD build.
srp is offline
Old 08-25-2016, 05:04 PM   #10
M12 x 1.75 x 50 MM Class: 10.9 Flanged/Automotive
https://www.fastenal.com/products/de...llowLinks=true
Bushings:
Yeah, I have read up on it. The lines are debatable, but '06+ 9-5 people said they have been fine with the stock lines.
I have also seen debate over which rotor to use. Local guy machined the hub to accept Cobalt rotors and is willing to machine mine as well, that is the route I am going.
Jameson is offline
Old 08-25-2016, 05:12 PM   #11
srp
srp's Avatar
Might as well put stainless lines on if you breaking them open anyway.
Then on to some 300mm rears
srp is offline
Old 08-25-2016, 05:28 PM   #12
That's the plan!
Jameson is offline
Old 10-04-2016, 12:08 PM   #13
I have everything I need aside from ordering the machined 315mm rotors from GS. I will tackle the install in 2-3 weeks.
Jameson is offline
Old 10-04-2016, 01:43 PM   #14
Cark's Avatar
Very Nice, your wagon is becoming ultimate
Cark is offline
Old 10-04-2016, 01:51 PM   #15
That's the plan!
Decided there is nothing that can take its place so dumping money to make it perfect.
Jameson is offline
Old 10-11-2016, 06:18 AM   #16
I bought all the components for the 300mm rear upgrade including Nick's slotted rotors to match the front 315mm ones I got from him.
Going to tackle the front install in less than two weeks with help from Sean(SRP) and may hopefully have time to do the rears as well.
Jameson is offline
Human Verification
