If you haven't cleaned your IAC.... - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > General NG900 / Old 9-3 Posts and Information
Old 02-15-2006, 08:45 AM   #1
Clean it now! its well worth it.
Background:
As the weather cooled down, my idle started to stick at 2krpms. Also after long trips, when stopping to pay tolls and whatnot, my car would stall out. I thought that was the extent of the problems.
How to: Sorry no pics. T5 ng900.
Remove plastic engine cover.
unscrew hoseclamps on either side.
AIC valve should be soup can sized thing just to the left of throttle body.
Peal hoses of either end.
Remove electrical connection, just squeze fitting and slide off.
Pull AIC and rubber bushing straight up.
Clean out with carb cleaner, and give a small shot of oil I used Penetrating oil.
Reinstall.
Not only did this cure my cold high idle off throttle, The car has never ran smoother. It doesn't even feel like its running at stops, and this is with a catless dp and saabsport. It also feels like it shifts better, probably because the rpms drop faster with the clutch in.
Seriosly if you haven't taken the time, its worth it. Its only a 30min job, and you only need a flathead screwdriver and some carb cleaner.
Old 02-15-2006, 09:45 AM   #2
stromer's Avatar
I'll add this to my list because I have similar signs as you did. I've never researched it before, so thanks for the concise procedure.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 02-15-2006, 10:14 AM   #3
VAGGEN's Avatar
Stooopid questions... IAC or AIC valve? What is it and what does it do?
2004 9-5 Aero Wagon - SOLD - and missing it
2004 S2000 - 31,000 miles and counting much more slowly
VAGGEN is offline
Old 02-15-2006, 10:16 AM   #4
BurnsSide42's Avatar
Use foaming engine degreaser - followed by rinse with HOT water (will evaporate most of the water after on it's own) and shake dry. (or blow out with compressed air) This is how I've done this everytime with success every time. Well worth the 10 minutes it takes.
Original TSL Founding Member
Check out European Motor Services, LLC for your repair needs
BurnsSide42 is offline
Old 02-15-2006, 11:14 AM   #5
Passion4_900's Avatar
Send a message via MSN to Passion4_900
AIC=IAC... "Automatic Idle Control"
basicaly controls the ammount of air going into the engine while you are idling. If you turn on the A/C, that puts a strain on the engine and without the AIC, the engine would most likely stall. When demand for the engine is greater, the AIC opens and lets more air in the engine to raise the RPM's a bit in order to keep up with the demand for engine power (A/C, rad fan, seat heaters...etc..)
- 2010 Camaro SS Cyber Grey - parked for the cold months
- 2001 9-5 2.3t - finally on the road
Passion4_900 is offline
Old 02-15-2006, 01:50 PM   #6
WyldSaabMan's Avatar
I like calling it the IAC so much more
Idle Air Control makes so much more sense in my head
99 Saab 9-3se Imola Red
90 Saab 900 SPG Talladega red
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
WyldSaabMan is offline
Old 02-16-2006, 05:04 AM   #7
mattlach's Avatar
Send a message via AIM to mattlach
What is this IAC of which you speak?
mattlach is offline
Old 02-16-2006, 07:05 AM   #8
well you Mr. aero with your T7 Dont have one, instead since your throttle body is electronic, the computer can just alter the throttle angle, and can control idle that way.
04 Yamaha YZF600R
00 Polaris XC700
99 Saab 9-3-RIP
98 900s N/A-RIP
Old 02-16-2006, 09:01 AM   #9
mattlach's Avatar
Ahh... I recently had to replace the throttle body because the coils in it were all messed up Kept kicking it into limp home mode...
mattlach is offline
Old 02-16-2006, 09:35 AM   #10
VAGGEN's Avatar
Thanks for the explanation! I am sure mine could use a good cleaning... every now and then I can feel the car "kick down" a notch, if you know what I mean.
VAGGEN is offline
Old 02-16-2006, 10:06 AM   #11
Eh - that's normal of those 9-5's - hope it was still under warrenty
Old 02-16-2006, 11:51 AM   #12
mattlach's Avatar
Sadly not. It started acting up a half a year out of warranty...
About the same time I had to change my DI casette... (cut I'm getting that one covered by the recall )
mattlach is offline
Old 02-16-2006, 04:23 PM   #13
VincentD's Avatar
Try Michel Briand's website, he's posted pictures of cleaning the IAC plus others...
http://pages.infinit.net/mlbriand/saab/iac/page1.html
VincentD is offline
Old 02-17-2006, 06:05 AM   #14
VAGGEN's Avatar
Nice! That was really helpful! Think I might tackle this on Saturday.
VAGGEN is offline
Human Verification
