Auto dimmer rear view question - The Saab Link Forums
Old 08-06-2012, 01:56 PM   #1
soccerrplyr's Avatar
Are all 99-2002 9-3's prewired for this. I'd like to install one but have never seen anyone with one or even in a car.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 08-06-2012, 03:02 PM   #2
nowhereman's Avatar
i didnt think any prewire was needed other than power as the self dimming mirror is selfcontained right? and doesnt your mirror have lights in it? (i have never had a 9-3 so dont know)
2008 9-3 SS: Stg 1
nowhereman is offline
Old 08-06-2012, 06:54 PM   #3
mcrowley's Avatar
All you need is switched power and a ground for the mirror. I installed one in my 900 (not pre-wired) - just ran a wire from the cig lighter.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-06-2012, 06:56 PM   #4
NickTurbo900's Avatar
My 97 900 was not prewired.
I don't think anything 9-3 will be wired either, except maybe an 02 9-3SE or a Viggen.
I pulled mine off the sunroof wiring.
Nice upgrade!
NickTurbo900 is offline
Old 08-06-2012, 09:03 PM   #5
PimpMyPc's Avatar
The auto dim requires a Y harness on the 9-3. The Y harness plugs into the front dome light and steals power from the switched map lights. I just soldered a power and ground wire up there.
PimpMyPc is offline
Old 08-07-2012, 03:26 AM   #6
were can i get a y harness
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 08-07-2012, 01:33 PM   #7
mcrowley's Avatar
I never used any kind of harness... Couple pieces of wire and some terminals, thats it.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 08-07-2012, 08:11 PM   #8
srp
srp's Avatar
Send a message via AIM to srp
The y harness used to be available from Saab. But it was something crazy like $70.
Like Mike said, just run some wires down pillar and tap into the lighter fuse.
srp is offline
Old 11-30-2012, 04:53 PM   #9
Nice upgrade!
what wires did you tap in the sunroof are? The harness that is on the cable appears to have 5 wires. i finally picked one up for 25 shipped and will do this as an afternoon winter project
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 12-01-2012, 04:45 PM   #10
As I recall, the 5 jumper down to 3 at the first connector.
One is ground, one is power. Pick them up anywhere you have ignition switched power.
The other is optionally hooked up to the reverse light hot lead to shut off the auto dim when backing up.
BobSabbert is offline
Old 12-02-2012, 12:55 AM   #11
Snabb SAAB's Avatar
Auto dim is over rated, I hate it. I have it on my 9-5 and I keep forgetting to go on eBay and buy a used manual mirror for the 9-5. Auto dimming is never dark enough for me, and I wish there was a button on the damn thing where I could just turn the dimming function on when it gets dark. On manual mirrors I just flip it to the dark side once night starts, leave it there until morning.
Current SAABs: 2000 9-5 Aero SC - 1987 900i 8v Past SAAB: 1995 900 SE Turbo
Snabb SAAB is offline
Old 12-09-2012, 09:45 AM   #12
My 2001 9-3 was not pre-wired. I bought it as a "S" model and installed the auto dim rear view mirror very easily. The kit included the wiring harness (a short "Y" connector wire assembly). Definitely an easy upgrade to do and well worth it. Unfortunately for me I did it back in 2002 when the mirrors were close to $200 new.
There is a button on mine to turn the dimming on or off if you want. I've never had an issue with it
"not dimming enough".
http://www.genuinesaab.com/psi/files/AutoDim9-3.PDF
Dean C is offline
Old 12-20-2012, 01:39 PM   #13
I tapped the red wire in the harness as I think this is the power and the black as a ground, then connected them to the cig lighter black wire as a ground, brown/green as a power. No go. anyone help! What wires would i be connecting
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 12-20-2012, 05:44 PM   #14
are you sure your $25 mirror actually works? did you bench-test it?
Craig R.
2000 9-5
g96nt is offline
Old 12-21-2012, 11:02 AM   #15
I tested today and its a no go. I used some wire extra car battery, a flashlight and couldn't get any movement. I even took the backing off and plugged into the harness where is says 12v and ground on the circuit board...nothing. I'll see what the seller messiguy01 on saabcentral has to say now.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 12-21-2012, 01:47 PM   #16
PimpMyPc's Avatar
Did you cover the front facing light sensor with black electrical tape and then shine a light at the mirror?
PimpMyPc is offline
Old 12-21-2012, 03:37 PM   #17
I tried it in a dimly lit room and shined a flashlight on the front first, then back looking and feeling for movement with the under button depressed as well as out
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 12-21-2012, 05:53 PM   #18
seller refund my money
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Old 12-21-2012, 08:12 PM   #19
PimpMyPc's Avatar
It doesn't move, but dims like a welding helmet. If you're not sending it back and just tossing it, I'm curious as why it failed.
PimpMyPc is offline
Old 12-22-2012, 06:02 AM   #20
i noticed no change in the unit or reflection at all
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
Human Verification
