gear oil / transmission oil - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > General NG900 / Old 9-3 Posts and Information
Old 06-12-2011, 04:05 PM   #1
Aikmanson's Avatar
Did a quick search on this, couldn't find exactly what I was looking for.
I lost a little oil when removing my passenger side axle + shaft. I plan on putting the new axle in and need to top off the gear oil.. what is the gear oil I need to get? In my manual it lists a manual transmission oil, and then it lists a gear oil... so which do I need? Can anyone throw me the eeuro link as well?
Thanks.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Old 06-12-2011, 04:55 PM   #2
WSW
WSW's Avatar
Mtf0063 I believe... That's whats recommended for my 98 tranny
WSW is offline
Old 06-12-2011, 05:05 PM   #3
Greek Mod
grkguy89's Avatar
Penzoil Synchromesh as suggested by Harvey's Auto
Current Activity: Moderating
grkguy89 is offline
Old 06-12-2011, 05:44 PM   #4
Aikmanson's Avatar
Hmm, and if it leaked out of the tranny where the axle connects, where do I add the oil?
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 06-12-2011, 05:58 PM   #5
WSW
WSW's Avatar
There's a fill plug below the brake fluid reservoir that takes a 1" socket
WSW is offline
Old 06-12-2011, 06:24 PM   #6
WSW
WSW's Avatar
That's where it's at on my car
WSW is offline
Old 06-12-2011, 06:31 PM   #7
Aikmanson's Avatar
Aha cool, thanks. Is it just fill it up till its at the top or? I am assuming there is no difference between a 9-3 trans and an NG trans. Especially since your's is hydraulic too.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 06-12-2011, 06:38 PM   #8
WSW
WSW's Avatar
There's a check plug somewhere too... When I replaced my axle I tried saving as much fluid as I can and jus eyeballed the rest that I lost when it spilled
WSW is offline
Old 06-12-2011, 06:45 PM   #9
yllwJet's Avatar
i would drain it all then put in syncromesh. if ur not sure whats in it,its not good to mix.
yllwJet is offline
Old 06-12-2011, 06:50 PM   #10
WSW
WSW's Avatar
Good advice, might as well replace the fluid depending on what's in there and when it's been replaced last
WSW is offline
Old 06-12-2011, 08:32 PM   #11
fiveiron9688's Avatar
There is a difference in the fill plugs. NG takes a 24mm socket, 9-3 is a hex (maybe 8mm or so?) in general. But I think something weird happens around '99...I don't remember.
1998 900 SE turbo convertible
fiveiron9688 is offline
Old 06-12-2011, 08:42 PM   #12
srp
srp's Avatar
Send a message via AIM to srp
Yeah drain and refill with MTF0063 or Redline MT-90.
srp is offline
Old 06-12-2011, 08:45 PM   #13
srp
srp's Avatar
There is a check plug by the drivers side axle shaft as well.
Oil level should be even with the hole. I just fill to the correct amount(1.8 litres; 1.9 quarts) and top off slowly till it starts to leak out of the check hole.
Courtesy of GenuineSaab.com:
srp is offline
Old 06-13-2011, 02:20 AM   #14
bogan's Avatar
Just changed mine 1 month ago
10w 30 mineral engine oil like speced in the manual
The syncros need the extra friction that the mineral oil provides
mine shifts like butter
bogan is offline
Old 06-13-2011, 04:03 AM   #15
Aikmanson's Avatar
Exactly what I needed to know, how much it takes. If it is only 1.9 quarts then I will just drain and refill with all new fluid.
So what is the best for these tranny's, and what weight do most of you run?
Thanks guys.
EDIT - just read the GS link there, seems to answer all questions. It does state to use "87 48 733" which results in this: http://www.eeuroparts.com/Main/PartD...px?id=93165414
My transmission is from a 2001 9-3 I believe. So after searching on eeuro for a 2001 9-3, it said get this: (the MTF0063)
http://www.eeuroparts.com/Main/PartD...px?id=93165290
So I guess follow the GS procedure, but use the MTF instead?
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 06-13-2011, 05:02 AM   #16
Ciscowned's Avatar
Some of the peeps are liking the Redline MTF (not shockproof or MTL). Even Nick stated that it felt better than MT0063 (linky). I'm using it right now and it works awesome. So long as it's GL-4 as our cars use brass synchros. I have a box full of Amsoil fluid I want to try.
Ciscowned is offline
Old 06-13-2011, 05:12 AM   #17
mcrowley's Avatar
If you've got a 9-3 trans I'd go with the MTF0063
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 06-13-2011, 05:51 AM   #18
Ninety5Aero's Avatar
I just picked up 2 qts of the recommended fluid for the Viggen and it was 93165414, Dexron VI. I got it from the dealer.
Ray
2000 Viggen 'vert
2000 9-5 Aero
1998 9000 CSE Turbo
1994 9000 Aero
Ninety5Aero is offline
Old 06-13-2011, 08:05 AM   #19
Aikmanson's Avatar
eEuroparts - Transmission Fluid (1L) - # 93165414
It doesn't SAY it is compatible with 9-3's, same as the "87 48 733".
I think I am going to order up 2 quarts (Liters) of the MTF0063
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Old 06-13-2011, 08:11 AM   #20
^^I know. That's what made me skittish about it. But that's what their computer said.
Ray
2000 Viggen 'vert
2000 9-5 Aero
1998 9000 CSE Turbo
1994 9000 Aero
Human Verification
