oil pump seal/o-ring replacement - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > General NG900 / Old 9-3 Posts and Information
Old 12-13-2010, 07:06 PM   #1
saabkid37's Avatar
so i stupidly called the local shop today since im working xmas and wanted to use my two days off after to relax rather than work on a car.
eeuro sells the two seals for about $12, shop wants $60, oh and $330 to put them in. WTF! 120 bucks an hour much?
needles sto say i need to do them myself so that i can put the evo away and drive the viggen for the winter.
any tips?
i have a feeling my 100 ft/lb air gun wont be able to handle the crank pulley bolt so a new gun may be necessary.
any recommendations on circlip pliers? i have the generic small craftsman ones that constantly snap the tips. im having trouble locating what i think would be an adequately large set.
any other tips? i know to line up the arrows when putting the pump cover back on i think thats about it?
saabkid37 is offline
Old 12-13-2010, 07:11 PM   #2
mcrowley's Avatar
It wouldn't hurt to clean off the oil pump gears when you've got the cover off. You'll need a serious pair of snap ring pliers to get that thing apart....I think the ones we used on mine we MAC. For the outer seal, use some assembly lube.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 12-13-2010, 07:25 PM   #3
BluAero's Avatar
Send a message via AIM to BluAero
I'll be keeping track of this thread, as my crank seal is leaking also. I ordered all the seals, just need to do the work.
BluAero is offline
Old 12-13-2010, 07:36 PM   #4
I actually managed to use the set of harbor freight pliers to get my oil pump cover off.
and back on. and off again, about 20 times actually.
I had a hard time getting the oil pump to prime but that was a whole different issue.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 12-13-2010, 07:48 PM   #5
saabkid37's Avatar
the question is how big. i cant find large ones.
i do not have a constant leak so im almost inclined to only do the outer seal.
or i could just stop being dumb and put the snows on the evo and push the viggen off a cliff.
Old 12-13-2010, 07:49 PM   #6
The snap ring is the real pita. I had to borrow a big set from work. Everything else is straightforward.
Tboy is offline
Old 12-13-2010, 07:56 PM   #7
This.
2012 VW Golf TDI
Old 12-13-2010, 08:08 PM   #8
saabkid37's Avatar
Originally Posted by PoisonBeef View Post
This.
its more of a dont wanna spend 500 bucks for a ski rack for the evo either...
Old 12-13-2010, 08:25 PM   #9
DeLorean's Avatar
Why would you not drive the Mitsubishi? It's a 4X4, isn't that the point of it, driving it in the winter? You could have just gotten the Mirage 1.8-L if you were not going to drive it in the snow
DeLorean is offline
Old 12-13-2010, 08:40 PM   #10
How much was the Evo?
500 bucks is what? 0.5% or less?
2012 VW Golf TDI
Old 12-13-2010, 08:51 PM   #11
saabkid37's Avatar
The rack would be an un necessary expense when I'm trying to recover from moving/initial apartment setup costs when I have a car with a full setup already.
Plus snow tires on viggen, all seasons on evo
Old 12-14-2010, 06:26 AM   #12
I've got a pair of long needlenose pliers with the ends bent in that work real well on the snap ring
seriks1 is offline
Old 12-14-2010, 09:24 AM   #13
I snapped a few pictures of the snap ring to give you an idea of how big it is.
Yes that opening is roughly 2" wide when not snapped in place.
The holes are close to 3/16 in diameter.
Hope this helps.
Tboy is offline
Old 12-14-2010, 09:44 AM   #14
Moreboost's Avatar
I thought you had the star specs on the evo?
Moreboost is offline
Old 12-14-2010, 10:13 AM   #15
saabkid37's Avatar
The only circlip pliers I can find that open far enough are snap ons and cost way too much.
Star specs/se wheels are off. I have two sets of wheels/tires
Old 12-14-2010, 11:32 AM   #16
DeLorean's Avatar
Harbor freight sells a nice tool for this, check there. It makes short work of this job, and the tool is pretty cheap. It's a very close copy to the snap-on unit thats 10X the price and is intended for use on automatic transmission snap rings.
DeLorean is offline
Old 12-14-2010, 04:40 PM   #17
saabkid37's Avatar
i checked the site quickly and didnt see anything. if i have time ill head down there this weekend.
Old 12-14-2010, 06:44 PM   #18
justineffingp's Avatar
HF is so hit or miss with tools, some of them do the job, some of them don't
justineffingp is offline
Old 12-14-2010, 08:52 PM   #19
srp
srp's Avatar
Send a message via AIM to srp
Find some used snows for the Evo. No trunk pass through on the Evo?
srp is offline
Old 12-14-2010, 09:35 PM   #20
candikid's Avatar
I don't know if you have "Knipex" here in the states, But they're very common in Norway, cheap and they get almost as big as you want them. Semi pro hardware stores usually have them.
9000CS 2.3 Turbo
candikid is offline
Human Verification
