900/9-3 Serpentine Belt thread. - The Saab Link Forums
Old 11-28-2009, 10:46 AM   #1
This is the best I could come up with. When 2 PK numbers are offered, i would suggest maybe going with the small of the 2 numbers. I will order a 6PK1800 for my car and give this theory a shot.
900 model 94-98
Stock:
49 04 728 aka 6PK2635
Short Belt (bypass middle idler)
49 61 066 aka 6PK2455
AC Delete belt and (not bypass middle idler)
43 95 406 aka 6PK2345 or 6PK2350?
AC Delete belt and (bypass middle idler)
49 61 058 aka 6PK1815
9-3 model 99-03(Vert)
Stock:
49 61 066 aka 6PK2345 or 6PK2350
AC Delete belt
49 61 058 aka 6PK1800 or 6PK1805
AC Delete belt Eary 9-3 with 4356127 Upper Idler Pulley
Up to Vin # X2028400
6PK1815
Also, if I have any mistakes, please let me know.
Old 11-28-2009, 02:45 PM   #2
comtrang's Avatar
Very useful info!
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 11-28-2009, 04:39 PM   #3
aireeca's Avatar
Great idea to pull all of this together into one place and sticky it. For the OG 9-3 belts, I believe the owner's manual goes with:
AC
6pk2345
Halp! My AC compressor wants to kill my belt (aka no AC aka short belt):
6pk1805
I've had both of those belts on the car and they run just fine. Then again, you already know that Tweek.
P.S. You're right, my engine bay is filthy.
aireeca is offline
Old 11-28-2009, 05:36 PM   #4
Send a message via AIM to gytre1 Send a message via Yahoo to gytre1
6pk1805 is an 1805mm belt and also a 73inch belt, im running a 72.5 inch belt with ac delete and bypassing the idler pulley.
gytre1 is offline
Old 11-28-2009, 05:38 PM   #5
Rudedog's Avatar
Goodyear Gatorback 4060967/6PK2455 with the Wazee idler pulley puts the marker at exactly the correct half way between the lines on my 1997 900SE bypassing the middle idler for the short belt mod.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 11-29-2009, 08:05 AM   #6
Randy, give us info on the diameter difference on the Wazee vs. the stock ng900 pulley
Old 11-29-2009, 09:08 AM   #7
Rudedog's Avatar
He used to have them on his website. I don't have them off hand but the pulley is almost dead on, maybe a hair bigger. I also have one on my '99 9-3 and kept the stock belt. Still well within the markings on the tensioner.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 11-29-2009, 09:37 AM   #8
Ok, I will have to see if I have my Short belt, and AC delete sizes backwards.
Can anybody verify?
Old 02-16-2010, 01:10 PM   #9
TheTalladegaKid's Avatar
I just talked to a mechanic about running a short belt on my 1997 ng900 and he said you can run a 6pk2415 but it needs to be super tight? I just called NAPA and asked how much it would cost and they said 53?! but when I looked at eeuroparts its like 30 bucks.
TheTalladegaKid is offline
Old 02-16-2010, 01:18 PM   #10
Rudedog's Avatar
Why would you do that? Buy the Gatorback that is 6pk2455 from Goodyear. It is a good belt and cheap ($30) because it is the same belt that is used on several of GM's truck motors.
RG Rude
WASSAAB member
2006 9-3SS Aero
Rudedog is offline
Old 07-12-2010, 12:38 PM   #11
mike d's Avatar
For informations sake, i ended up doing a short belt on a 2002 9-5 aero. the 2455 was a hair long for skipping the middle pully, but a 6pk 2440 worked perfect!!
good info tweek
MikeDTuning.com
mike d is offline
Old 09-11-2010, 03:59 PM   #12
Aikmanson's Avatar
good info tweek
Not to resurrect a dead thread but, I too just installed a 6pk2440 on my 1995 NG900 2.0L Turbo. It fits perfect, and was only 38 bucks.
Current Cars
2010 Mini Cooper S
1991 Miata
1995 900 SE Turbo
Aikmanson is offline
Old 11-09-2010, 01:38 PM   #13
drewz airflow se's Avatar
Having trouble getting the short belt on bypassing middle idler. I have a ribber wazee pulley in there. I do have a brand new stock belt on hand too. I may throw that on.
^CLICK ME^
drewz airflow se is offline
Old 11-09-2010, 01:54 PM   #14
Marks9-3's Avatar
Sure you have it routed the right way? Should actually be easier then going around it.
Marks9-3 is offline
Old 11-09-2010, 02:08 PM   #15
i am hoping they sent me the right belt. is this right?http://www.eeuroparts.com/main/partd...spx?id=4961066
^CLICK ME^
Old 11-09-2010, 02:13 PM   #16
Marks9-3's Avatar
That should be, the middle idler was bypassed (well, not there) stock on the 9-3's
Marks9-3 is offline
Old 11-09-2010, 02:15 PM   #17
Do I put it around the A/C?
^CLICK ME^
Old 11-09-2010, 03:05 PM   #18
Marks9-3's Avatar
Yeah, that one is for when you use the AC.
Marks9-3 is offline
Old 11-09-2010, 04:25 PM   #19
I will try again tomorrow.
^CLICK ME^
Old 11-10-2010, 03:50 AM   #20
mcrowley's Avatar
Drewz...if you're using the Wazee pulley you need a slightly shorter belt than the 9-3 one.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Tags
belt, drive belts, serpentine belt
Human Verification
