removing shift knob - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > General NG900 / Old 9-3 Posts and Information
Old 08-23-2009, 07:38 PM   #1
removing shift knob
how do you remove the shift knob on a 9-3?
spgstud is offline
Old 08-23-2009, 08:18 PM   #2
Smaart Aas Saabr's Avatar
hacksaw
Smaart Aas Saabr is offline
Old 08-23-2009, 08:21 PM   #3
turbojohnny's Avatar
yeah pretty much you have to destroy the old shift knob if you want to replace it with a new one.
well just to get it off you have to destroy it lol
turbojohnny is offline
Old 09-03-2009, 06:16 PM   #4
shift knob
if you mean just the shift cap, the rubber part with the 5 speed grid on it, then just twist it like a bottle cap to release the glue then pull it straight up. there is a black ring that will come loose which just fills in the bottom of the cap and keeps it tight, if you're replacing it just glue up the black ring put some glue in the top of the cap and pop it on.
saabsw is offline
Old 09-03-2009, 06:26 PM   #5
srp
srp's Avatar
Send a message via AIM to srp
I wrap the knob in a clean rag and use a strap wrench to break the glue free. Then just lift up.
srp is offline
Old 09-03-2009, 06:40 PM   #6
viggenkid's Avatar
i just grabbed it and pulled up. hard.
took some force but it popped right off.
viggenkid is offline
Old 09-03-2009, 06:57 PM   #7
dan-the-kid's Avatar
Not every one is as strong as you Craig.
dan-the-kid is offline
Old 09-03-2009, 06:58 PM   #8
srp
srp's Avatar
I'd be more concerned about breaking the plastic ball mount or reverse/5th gate by brute forcing it.
srp is offline
Old 09-03-2009, 07:02 PM   #9
viggenkid's Avatar
i actually pulled off the reverse/5th gate as well. its just a friction fit. put the new knob on and tap the whole assembly back into place.
Old 09-04-2009, 08:29 AM   #10
Passenger 57's Avatar
a 1" wrench is the perfect size for removing the knob. Lift the reverse gate up, put the wrench under the knob, smack the wrench with a hammer, the knob should pop right off. Another pair of hands can make it alot easier.
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Passenger 57 is offline
Old 09-04-2009, 05:32 PM   #11
Paul Campagna's Avatar
there is three clips inside the knob. put something in there to relase them and the knob comes right off.
Paul Campagna is offline
Old 09-04-2009, 07:22 PM   #12
srp
srp's Avatar
I believe he is taking about removing the shift knob from the shaft. Not from the boot/reverse lock out piece.
srp is offline
Old 09-04-2009, 10:00 PM   #13
NahumCC's Avatar
What was showed in the above post in the photo's is the exact correct process for removing the shift know itself to replace it.
When you use the wrench and hammer method you'll expose those prongs which latch onto the knob from underneath. Depress the clips and remove.
2013 FR-S
NahumCC is offline
Old 09-05-2009, 09:38 AM   #14
The knob was supposed to have been epoxied onto the shaft from the factory, so if the epoxy hasn't been broken and isn't brittle enough to just crack, releasing the 3 clips isn't going to make the knob pop loose.
Jeremy R. is offline
Old 09-05-2009, 10:06 AM   #15
If you need to remove the "shift knob assemble" which combines the knob and leather gaitor, just pull really hard upward and don't smack yourself in the face (ask me how i know.)
Just the knob from the assemble is what I am showing.
Wasn't the question for a shift knob?
Old 04-03-2012, 12:58 PM   #16
beyonce's Avatar
I'm at wits end with this thing. I just installed a short shifter and now I'm trying to transfer the boot and knob from the old shifter. I ran a knife along the underside of the knob and removed the black plastic ring. All I've gotten so far when I pull up on the knob is it clicking past those three tabs and then it stops, which is about a half inch up.
There must be a real way to do this without having to destroy the old one!
beyonce is offline
Old 04-03-2012, 01:23 PM   #17
Did you view the post above with the images? Those three tabs need pressed down as you lift up on the leather part until the knob comes off. ( I just got the short shifter kit as well and will be doing this very shortly...) I might missunderstand where you are in the process, but i've done it several times without issues.
Old 04-03-2012, 01:57 PM   #18
beyonce's Avatar
I figured it out. I was pulling up by grabbing the knob, but what I was SUPPOSED to be doing was grabbing the black sheath that goes over the shift rod. Earlier I was delicately prying at it with a screwdriver to see if it was held on by tabs as well...but the whole thing slides on and off with a bit of convincing.
And yes, I did read the earlier post and didn't see or feel the tabs. When I pulled up and twisted on the knob it came right off of them, however.
beyonce is offline
Old 04-04-2012, 04:53 PM   #19
Help me out... I need to do this too.
So the steps are:
1. Twist the knob to break the epoxy free
2. Do I slip some thin things in to release the three clips next? Do I pull on the leather knob or the whole reverse tube/mechanism?
BobSabbert is offline
Old 04-04-2012, 04:56 PM   #20
srp
srp's Avatar
I usually just power shift into 4th gear with the motor off.
Just put it in 4th and pull up.
srp is offline
Human Verification
