Help with my broken door handle (cable maybe) - The Saab Link Forums
Old 11-19-2007, 03:36 PM   #1
booyakasha07's Avatar
My buddy tried to open the locked passengers door last night and he pulled on the handle normaly and something popped... cant open the door from the inside, does anyone know if there is a cable or something that runs to the latch that lets the door open? Should i try and open this and look for myself?
Thanks
~Bryce
booyakasha07 is offline
Old 11-19-2007, 03:38 PM   #2
AeroDynamic's Avatar
Send a message via AIM to AeroDynamic
taking your door panel off is a good first step.
WHATS YOUR ALTITUDE?
510whp @18psi @5600rpm's "600HP or parts on the floor"
AeroDynamic is offline
Old 11-19-2007, 03:39 PM   #3
liketheword's Avatar
Not all of us have "only" 3 doors to worry about.
ps. Put some Inca's on and the door will weld it self shut.
Vitamin SAAB
liketheword is offline
Old 11-19-2007, 03:43 PM   #4
Whats a three door have to do with anything? These locking systems are not that complicated. If it was a 9000 I would give him specific instructions on how to fix it but its a ng900/93 so I am sure things are a little different.
Taking something apart and looking at it is a good first step to solving the problem.
Old 11-19-2007, 03:43 PM   #5
b dash rian's Avatar
pop the door panel off, also pull out the handle (there is a screw on the handle, look closely). its a bit tricky, but not too bad (especially once you've done it a few times) to reconnect the inside lever to the arm in the door.
b dash rian is offline
Old 11-19-2007, 06:50 PM   #6
This may help you to take the door card off to see what went wrong.
http://www.saabcentral.com/~munki/te..._door_card.htm
hkayssi is offline
Old 11-05-2008, 08:21 PM   #7
aireeca's Avatar
Hey-ya! Can anyone tell me whether the above link is the same for a OG 9-3 five-door. Something popped in the door and inside door handle no worky anymore.
Last edited by aireeca; 11-05-2008 at 08:22 PM. Reason: Feeling less like Letterman and more like I should be shakin' it like a Polaroid picture. You know what to do.
aireeca is offline
Old 11-07-2008, 04:13 AM   #8
coreyeroc's Avatar
there is no cable - i bet what poppoed off was the little metal linkage arm that connects the inside door handle. Pop off the little circular trim piece inside the door handle, there is a torx screw behind it, a t20 I think. Pop out the trim piece, and handle, you'll see the linkage arm behind it. theyre extyremely easy to put back on. you just sort of set it with the handle itself, kinda hard to explain, but you'll see once you get it off.
coreyeroc is offline
Old 11-07-2008, 05:01 AM   #9
aireeca's Avatar
Cool. The door was locked when this happened and I definitely heard a "pop" rather than a shatter or something else along those lines.
Tomorrow morning is all-Saab-fixin'-all-the-time. And, amazingly, two-thirds of the repairs are to Saab door issues. Wheee!!!! I'll try to take photos and post up a how-to.
aireeca is offline
Old 11-07-2008, 05:52 AM   #10
coreyeroc's Avatar
what other kind of door repairs are you doing? I've been through/in/out of every single one of these damn doors. maybe I can help?
Old 11-07-2008, 05:56 AM   #11
aireeca's Avatar
Well, I'm going to replace the window rollers while I'm in there, mostly because they make a "ker-chunk" when the window is about two-thirds down. Is there anything else I should clean, oil, attend to while I've got the panel off?
The other door repairs involve my c900 and tossing a new piece of passenger's side window glass in there. That's not going to be too hard, though. Door panel off. Vacuum up broken glass. Get remainder of old piece out. Screw in new piece. Tada!
aireeca is offline
Old 11-10-2008, 10:35 AM   #12
I fixed the door myself it took 20 mins very easy to do.
Old 11-10-2008, 10:50 AM   #13
aireeca's Avatar
Cool. I think I'm going to strap on the old headlamp from the Canada trip and get to fixing this tonight. It is getting old, real old, having to climb across the passenger seat to get out of my damn car.
Did you have to take the whole panel off or just the little door handle trim?
aireeca is offline
Old 11-10-2008, 11:23 AM   #14
coreyeroc's Avatar
so what'd you figure out with this problem last weekend??
If you're trying to fix the rollers also, you'll need to take off the whole door panel - but they're really easy to get off as well. Three torx bolts on the underside of the panel, the one behind the door handle trim, and popping off the other side mirror trim pieces to do this..
You should definitely oil the cable and pieces that control the window regulator, and any other moving parts.
Old 11-10-2008, 11:27 AM   #15
aireeca's Avatar
I didn't get time to do this last weekend. Putting the c900 back together ended up taking more time than I thought. I snagged some green rollers from the local dealer and I think I'm just going to the quick fix tonight and save the rollers for this weekend or next because there is S-N-O-W falling lately in Cleveland and the c900, even though it is just a base, need not be rollin' in that.
aireeca is offline
Old 11-11-2008, 02:45 AM   #16
coreyeroc's Avatar
you people that have dealers in your town are LUCKY. There isnt a Saab dealership within 70 miles of here. However, the BEST Saab repair shop is 4 hrs away, Taliaferro Saab in Springfield.
Old 11-14-2008, 04:30 PM   #17
aireeca's Avatar
So, I finally got around to pulling the handle out of the door tonight. That little hooky part that's supposed to catch on the door release?
Busted.
Gone.
Broke.
Yuck.
I'm leaving it off because, at least with it off, I can use a screwdriver to let me out of the damn car.
Boo.
aireeca is offline
Old 11-17-2008, 03:13 AM   #18
coreyeroc's Avatar
crap.. I just gave away two of those door handles a couple weeks ago. Junky yard time.
Old 11-17-2008, 05:33 AM   #19
aireeca's Avatar
Yeah, well we'll see about that. The one u-pull it I've found around here doesn't have anything newer than 1990 and eEuro wants $44 new. Might be time for eBay or car-part.com. The first snow (and salt) flew last night, Little Red c900 has been put to sleep in the garage and I foresee using my key or a screwdriver to open the door getting old fast.
aireeca is offline
Human Verification
