Need smaller belt. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 08-25-2011, 06:52 PM   #1
Send a message via AIM to IceTea
Need smaller belt.
Just got rid of my A/C. Need website to get one.
Need a link, and size.
IceTea is offline
Old 08-25-2011, 07:00 PM   #2
132417SAAB's Avatar
The Saab Link Forums - Search Forums
95 9k Aero 258k stg: vainly attempting to make a 258k car turn key
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 08-25-2011, 07:39 PM   #3
2325 mm length 6 rib. Dayco 6pk2325 is what Ive got.
gustav is offline
Old 08-26-2011, 12:55 PM   #4
2345mm long 6 rib 20mm wide.
Any difference between the two sizes?
IceTea is offline
Old 08-26-2011, 12:57 PM   #5
Same size.
Sigless....for now.
Old 08-26-2011, 12:57 PM   #6
WSW
WSW's Avatar
Length
WSW is offline
Old 08-26-2011, 12:58 PM   #7
Originally Posted by WSW View Post
Length
I see what you did there!
Sigless....for now.
Old 08-26-2011, 12:58 PM   #8
Length
Which ones better?
IceTea is offline
Old 08-26-2011, 01:00 PM   #9
Originally Posted by mike saunders View Post
Same size.
2325 & 2345.
Hmmm, the same? What do these numbers stand for?
IceTea is offline
Old 08-26-2011, 01:05 PM   #10
2325 & 2345.
The belt number is usually the belt length in MM (although Gates might have its own system)
My comment referred to Gustav's post, where he gave the belt no.# and the length and width
Sigless....for now.
Old 08-26-2011, 01:08 PM   #11
Is the smaller length better, or the larger one? What one would you go with?
IceTea is offline
Old 08-26-2011, 02:54 PM   #12
WSW
WSW's Avatar
You like that don't you
I'm not sure which belt is best.. You have to find the perfect one as you don't want it top tight and you also don't want it too loose
WSW is offline
Old 08-26-2011, 04:31 PM   #13
Shorter belt is best. Ive had both . Longer one destroyed tensioner as it was to far extended. Mind you I have only been running the short one for 6000 miles did about 30000 miles on the other.The long belt had to much deflection right from the start so Im picking Ive got it about right this time. 2325 is length in millimeters
gustav is offline
Old 11-25-2011, 01:39 PM   #14
sona's Avatar
Send a message via AIM to sona
I know I'm bumping an old thread, but I was curious if you've had any trouble running the 2325 mm belt since you've posted this?
-1991 9000 Turbo
-1994 9000 Aero
-2006 Explorer Eddie Bauer
sona is offline
Old 11-25-2011, 02:22 PM   #15
zach9000's Avatar
I got a short belt from europe perfect fit 20 bucks.
Stance.
Nothing else matters.
zach9000 is offline
Old 11-28-2011, 10:34 PM   #16
Correct sizw 2.3 w/o AC is 2317mm according to your Saab owner's manual, so anyone with something longer might experience problems down the road.
Aerohead is offline
Old 11-29-2011, 05:12 AM   #17
mvadenais's Avatar
I have been running a 2318x20mm belt Gates brand part code/number K060908/6PK2305. No issues at all. 2325 seems too long
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 11-29-2011, 12:21 PM   #18
2325 belt is still okay on mine , it hasnt been in more than a year though so cant swear by this length . The tensioner working further extended than originally designed for seems to be the issue.
gustav is offline
Old 12-04-2011, 02:20 PM   #19
sona's Avatar
Amazon.com: Bando 6PK2305 OEM Quality Serpentine Belt: Automotive Amazon.com: Bando 6PK2305 OEM Quality Serpentine Belt: Automotive
Link to Bando 6PK2305. Says it's 2305 mm... you said you were running a 2318 mm? I'm confused.
-1991 9000 Turbo
-1994 9000 Aero
sona is offline
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
