How do you remove the leather shift knob and boot - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 10-10-2010, 03:37 PM   #1
drewz airflow se's Avatar
I want to pull the shift knob and boot out of the aero and put it in the ng does anyone have any pointers on how to do it?
TIA
Drew
^CLICK ME^
drewz airflow se is offline
Old 10-11-2010, 04:06 AM   #2
BurnsSide42's Avatar
Good question - I too would like to know as I have never had to do this and would like to install a leather shifter boot onto my 86' I only know how to remove them in junk yards... and the knobs are not re-useable then.
Original TSL Founding Member
Check out
for your repair needs
BurnsSide42 is offline
Old 10-11-2010, 04:53 AM   #3
Svenska94Aero's Avatar
Send a message via AIM to Svenska94Aero
Pull the boot first by removing the single screw on the trim plate of the console. Sometimes it's hidden under the bottom edge of the boot. To pull the boot off the trim plate, there is a spring-cord sewn into the boot which pull it tight when you slip it over the ridges, so you just need to pull on a corner, lift it above the ridge on the trim plate and just work it off, shouldn't be hard once you get it started. If you want to separate the boot from the knob, you have to clip or unwind a ziptie, you'll notice that when you pull the boot up. Then to remove the knob you just pull really hard. Some heat might come in handy to loosen the epoxy. Good luck!
1973 99 EMS - Big plans
1990 900 SPG - Go-kart with a Holset
1995 9000 CS - PITA
Svenska94Aero is offline
Old 10-11-2010, 05:09 AM   #4
Hmm - I was afraid that was going to be the only way... 25 year old epoxy is either going to be on there way too good, or pop off and hit me in the face. lol fun fun
Check out
Old 10-11-2010, 05:14 AM   #5
Talladega900's Avatar
Wear a faceguard....
Jim Miller
'91 900 Turbo SE Convertible
'93 900 Turbo CE #116, modified
'02 9-5 Aero SportWagon, MT
'06 GTO, modified
'08 9-7X 6.0 Aero. The fastest stock Saab I've owned, bar none.
Talladega900 is offline
Old 10-11-2010, 07:11 AM   #6
yeah that's definitely the fun bit. The other option would be to buy a new knob, then you can just cut the old one off with a dremel. That's what I did for mine.
1995 9000 CS - PITA
Old 10-11-2010, 07:55 AM   #7
JK
JK's Avatar
I've never had to cut off a shift knob, I typically just grip it firmly, wiggle, and pull up. Never, ever had an issue getting one removed. I probably have had a black eye or bruised hand from doing it though.
always a SAAB guy at heart
JK is offline
Old 10-11-2010, 09:39 AM   #8
What do you all use to re-install it? JB-WELD? lol
Check out
Old 10-11-2010, 02:57 PM   #9
or, in case you have to do it again in the future, a set screw under the boot
1995 9000 CS - PITA
Old 10-11-2010, 03:02 PM   #10
JK
JK's Avatar
Uh...friction? Same thing that held it on in the first place.
Just to make sure I'm not on crack, I just went outside and pulled the knob off of the three 9000 shifters I have sitting around. They all pulled off. The shaft is splined and the knob friction fits on there. You can't be a sissygirl about it, just grip, and pull/wiggle it off.
JK is offline
Old 10-11-2010, 05:29 PM   #11
Did it today for one pull and pop it was off. The boot was easy too. Not sure its going to fit the ng though. I put it on anyway.
^CLICK ME^
Old 10-12-2010, 05:01 AM   #12
Glad it worked for ya!
1995 9000 CS - PITA
Human Verification
