Torque spec for valve cover bolts? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9000 Forum > General 9000 Posts and Information
General 9000 Posts and Information Please post general information pertaining to the Saab 9000.
Old 03-10-2009, 09:09 AM   #1
tuner4life's Avatar
How tight are the valve cover bolts supposed to be, I tightened mine up a little bit too tight in an effort to get it to stop leaking and cracked it. I have a new one now, would like a torque spec or something so I dont have that happen again
Also what are the tricks to seal up the valve cover gasket, I have had all kinds of problems getting it to seal. I put some rtv in the groove on the vc in the corners and in the crescent parts, is that enough? What is the right way to get this f@#&ing thing to seal?
-Jason
1986 Saab 900 Turbo & 1992 Saab 9000 Turbo
tuner4life is offline
Old 03-10-2009, 09:40 AM   #2
Green9kAERO's Avatar
tight enough to hold it securely, without breaking it.......
I think like 14 Ft lbs
i just use RTV or something in the Valve cover and put the gasket over it, no problems and ive done this to more cars then i care to remember. maybe your Valve cover was leaking, and you made the problem more odvious with the overtorqueing?
Green9kAERO is offline
Old 03-10-2009, 09:42 AM   #3
Castor Troy's Avatar
same. i just tighten it till it's reasonably tight. i also RTV the entire gasket, but thats mostly because i dont like fighting to keep the piece of shit from falling out.
you should use a new gasket every time you remove the valve cover, as well.
Castor Troy is offline
Old 03-10-2009, 09:44 AM   #4
same id put the gasket in dry if it would stay in there...
have you tried another gasket, maybe it was faulty?
JP
Old 03-10-2009, 09:45 AM   #5
i have yet to replace my valve cover gasket and I have had it off 3 or 4 times... no leaks yet...
Knocks on wood.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 03-10-2009, 10:10 AM   #6
Palla2442's Avatar
Send a message via AIM to Palla2442
Knocks on wood.
same i have taken mine off probably more than that. I dont even rtv it either
Palla2442 is offline
Old 03-10-2009, 11:04 AM   #7
moose's Avatar
11 ft. lbs.
trying buying a new rubber seal, they are cheap. yours could be to old and flat.
its a bitch to try and get a new one to line up but you won't have any problems with sealing.
undercover Moderator
Stg. no go
moose is offline
Old 03-10-2009, 11:23 AM   #8
tuner4life's Avatar
ok, thanks. I will see of the gasket I have sitting around will work, if not I'll be buying a new one.
-Jason
Human Verification
