I have a 2004 9-5 arc. MAy Need to replace oil completly!
Rite now I am looking at a Mityvac for about 30 bucks. As a vacum.
Should I consider a compression unit (seems like the better method?) as in the Motive Bleeder Unit ? about 50 bucks. BTW IF you need to drain completly is this method ok for the master cylinder?
Should I get them both? since I have some motorbikes too that need tending? (vacum only)
My girl has a newer volvo v70 that I have to do next. Will it work for that?
Any and all input helps thanks!
Must move fast on this!
