as of late i have noticed it has been very difficult fueling up my 9-5. Almost as if the gas pump's rubber boot "vapor protector" or whatever its called is not forming a good enough seal on the cars fuel filler neck which then leads to the gas pump cutting off as if the tank is already full. I have tried fueling in every angle possible and its becoming a major PITA.
The only way that i found that works is to jam the pump way in there and carefully hold while compressing the handle on the lowest setting possible.
It takes me about 15-20 minutes to fill my tank.....and on top of all that I can never tell if its completely full until I get in the car and turn the key.
this is getting old really fast......anyone have this same problem filling up? Its probably not good "health wise" to spend 20 minutes filling up and having the gas pump "top off" like 100 times before the tank is full.
the only thing i could really think of was that the rubber boot on the gas pump housing is not forming a proper seal around the filler tube.
I really miss the days when you stick the gas pump in your car, click your desired setting and let it do its thing!
