So what are you guy's seeing for oil pressure. Trying to get an idea of whether or not I should bother dropping the pan. Fresh 5w40, nice and hot, seeing around 21psi at idle and 36 psi @ 2000 rpm. This is on a 100k mile b235r, I wouldn't think being 3 psi off spec is any big deal. But out of curiosity does anyone know what those with sludge problems see for pressure?
01' viggen, I just figured I would get more b235 info in the 9-5 section. I thought readings looked pretty good, again just curious as to what others thought.
BTW Brad, I tried to return your call the other day but never got threw.
Spec is temperature dependent. IIRC, it is 32 psi at 2000 rpm, at 221 degrees F oil temp. And 11-14 psi at idle.
At that temp, my 132k 9-5 Aero does 30 psi at 2000 rpm and 11 psi at idle.
26.9K members
