quite a while ago i bought the LED switchback bulbs http://autolumination.com/switchback.html and if none of you can remember here is a video of them on my car...
[/URL][/IMG]
...now as you can see the bulb blinks faster because the LEDS take up less power, and the system thinks a bulb is out. i then found that you can't just change out a fuse because the blinker system is controlled by the computer. well i finally asked the Saab tech at work today and he told me that you can't reflash the ECU to compensate for this. i then thought about putting in a resistor, but i don't think i want to mess with cutting wires and plus what would i do if i put in a regular bulb later?
looks like i'm stuck with an annoying fast blinker. unless someone else has any ideas
