ok guys i replaced my drivers side foglight that had a broken bracket. The fogs and my blinkers worked fine prior to removal. Note the 2nd bulbs in the foglights were removed because i didnt want thefoglight blinking.
anyhow i swapped the old one out with the new foglight, the foglights work as normal however my blinkers no longer work. I hit the lever and get nothing, no blinker sound, not blinker indicator on the dash....nothing.
do you think its a short somewhere? do you think my blinker lever finally failed?
i put the 2nd bulbs back in the foglights to see if that was causing a short somehow but still nothing.
i checked the DICE indicators fuse and its fine.
the blinkers work when the alarm is set and when the hazard button is pressed
Anyone had this problem?
