Joined the 9-5 Club - The Saab Link Forums
Old 10-21-2016, 10:41 AM   #1
WSW
WSW's Avatar
Joined the 9-5 Club
Was scrolling through copart and seen this 03 Aero in Virginia with a buy it now price of 300. Was a donated and runs/drives listing. Had to jump on it as being a Virginia car it was most likely rust free
I went through a broker and bought it right away. After copart/broker fees and
shipping it to Chicago It was 1500
Arrived a few days later, checked it over and not a spot of rust. Underbody is super clean. Ran good overall
158k, 5 speed, fully loaded with vented seats, xenons, park assist, homelink/compass mirror, auto dimming side mirrors , rain sensing wipers, etc
Compression 180 on all 4
So far I have replaced the shift knob, fixed leaky sunroof drains, repaired sunroof deflector, installed pcv update, dropped pan, new maf,dic, coolant temp sensor, thermostat, fresh coolant, new coolant bypass valve, new fuel filter, new plugs, new cabin filter, new valve cover gaskets, replaced peeling onstar antenna with a dummy, replaced windshield cowl cover, new wiper blades, replaced batteries in alarm module, 666 lighting relay mod,silicone vac lines, debadged on the rear, replaced numerous interior bulbs
Still left to do: passenger rear regulator, install GS poly Trans mount, restore headlight lenses, clean engine bay, replace passenger fender as it hAs some deep scratches, figure out p0442 cel and give it a proper detail.
Paint needs some loving for sure but I've done half the hood and she shines right back up
Def needs engine/Trans mounts soon and maybe subframe bushings.
There was an 01 9-5 at the junkyard had eibach springs and shocks/struts so I installed those minus the fronts as they're different
Came with turbines but I was flipping a silver Aero so I swapped wheels and put the rk2s on, they need to be refinished( plan on doing it over the winter)
My first 9-5 and I'm in love, great daily driver
Got the itch to start modding it already
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-21-2016, 11:42 AM   #2
turbojohnny's Avatar
you posted this, and didn't post any pictures?! How could you?!
turbojohnny is offline
Old 10-21-2016, 12:16 PM   #3
WSW
WSW's Avatar
Pictures not popping up?
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-21-2016, 04:11 PM   #4
jk88's Avatar
That thing is sweet. Congrats!
(also deleted the dupe and made the edit per your request)
88 900TC
02 Viggen
jk88 is offline
Old 10-21-2016, 04:45 PM   #5
WSW
WSW's Avatar
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-21-2016, 06:54 PM   #6
Only issue is, a properly modded 9-5 makes one look at their Viggen differently.
Jameson is offline
Old 10-21-2016, 07:55 PM   #7
Troup's Avatar
Send a message via AIM to Troup
He saw mine and just had to have one.
-1992 9000
-1994 9000 Aero
-2002 9-5 Linear
-2006 Explorer Eddie Bauer
Troup is offline
Old 10-22-2016, 04:26 AM   #8
Awesome find, you are ticking off all of the weak spots for sure!
Tboy is offline
Old 10-22-2016, 04:48 AM   #9
I had the GS trans mount.
I chucked it for a powerflex mount after it eroded like a PPS poly bushing.
The new aero needs one, and It'll be a powerflex, as well.
for the rest, the hutchinsons on Ebay are OE quality, and are pretty inexpensive.
I can't see the pictures, but I'm stoked for ya!
9-5 club is where it's at!
If you have to replace the headlights, DDM makes a GREAT D1S, and awesome CREE foglight bulbs.
Craig R.
2000 9-5
g96nt is offline
Old 10-22-2016, 04:53 AM   #10
Drew In Houston
Good find for sure. It even has the front lip intact. I looked for vented seats for awhile and still haven't came across an example with a manual. Somehow you corner the market all the highly optioned Saabs lol.
You might consider dropping the oil pan for a look-see and going through a preventative head re-torque procedure.
I'm DD-ing a 5-sp '03 Aero with +200k miles at this point, it's awesome, although it doesn't have all the options like yours. It did have some buildup in the pan, and it did develop a mild coolant leak into the cylinder when parked overnight around 170k or so. When I did the head gasket the cross hatching was still visible in the cylinder walls and the timing chain tensioner was only extended about half way, I think +300k miles shouldn't be a problem at all.
Trionic3000 is offline
Old 10-22-2016, 06:10 AM   #11
WSW
WSW's Avatar
Are the pics not popping up?
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-22-2016, 06:13 AM   #12
WSW
WSW's Avatar
Pan wasn't too bad for not having pcv update, seems like oil was changed regularly and with synthetic
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-22-2016, 06:38 AM   #13
WSW
WSW's Avatar
I do want that spoiler
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-22-2016, 01:02 PM   #14
Drew In Houston
Looks like you got a good one.
Old 10-22-2016, 01:55 PM   #15
All told how much do you have in it now?
Tboy is offline
Old 10-22-2016, 03:51 PM   #16
WSW
WSW's Avatar
2000 with all the maintenance parts
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-24-2016, 02:43 AM   #17
very nice
Old 10-24-2016, 07:32 AM   #18
Wagon Shaggin'
Saabeh's Avatar
Nice find. Also +1 on the powerflex bushings. Do the trans and subframe side.
Saabeh is offline
Old 10-25-2016, 04:17 AM   #19
WSW
WSW's Avatar
Pulled off the door panel to replace the passenger rear regulator and come to find there's no regulator. Seems like original had failed so they removed it completely and rigged glass to stay up.
Anyway she's good to go now with a used regulator
99 Viggen
03 9-5 Aero
WSW is offline
Old 10-25-2016, 01:16 PM   #20
WSW
WSW's Avatar
Restored the headlight lenses today
Before :
After:
99 Viggen
03 9-5 Aero
WSW is offline
Human Verification
