Gauge Project - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > Customizing Your NG900 or old 9-3
Old 09-18-2012, 09:13 AM   #1
StoneSilver's Avatar
Gauge Project
So I bought One of these, and it was a peice of junk, ripped apart my whole dash and it didnt fit
52MM (2") TRIPLE DIN RADIO 3 GAUGES IN-DASH PANEL POD (FIT STANDARD RADIO SLOT)B | eBay
Realizing I have so many useful tools at my disposal such as computer controlled Plasma/Laser cutting table and lots of computer software, I decided to start making my own
First one with 2 gauge holes and "SAAB" cut out(not all the way threw)
Im going to try with many different types of Materials and Designs and ill post more pictures along the way.
Ive got a order of .25in thick Black Plexiglass on the way
Any other Ideas for things to make are welcome
2000 9-3 SE - BCB Tuned
2008 Evo X GSR
Now the Car Gods @ DOT are gunna come Smack your PE PEE
StoneSilver is offline
Old 09-18-2012, 09:57 AM   #2
That's cool!
I would stick with three holes. How small can you cut the text? I think a small size font, and shallow cut would look nice and understated. Maybe put them on the bottom, between the three gauges. Spot on the left could say "Saab" and the other side could say "9-3" or something.
BuHuSPG is offline
Old 09-18-2012, 10:48 AM   #3
Where are you going to mount this I want one
hvaclander is offline
Old 09-18-2012, 11:09 AM   #4
oooooohhhhh realllly? Details please!
What CAD software are you using?
Used Saab Parts:
'92 9000T, 5MT, Black (Twins!)
Also Caring for: '02 9-3 SE, '91 9000T, '97 9000CSE, '98 9000CSE, '99 9-5, '00 9-5
dantinne is offline
Old 09-18-2012, 11:27 AM   #5
The software is AutoDesk Inventor Pro. Really fun program. I pm'd you.
2008 Evo X GSR
Old 09-18-2012, 03:31 PM   #6
secret ingredient's Avatar
Looks good. Plans to produce more than one?
1983 900 8v turbo- sold
1998 900 SE- sold
1995 9000 CSE
secret ingredient is offline
Old 09-18-2012, 03:46 PM   #7
It mounts right above a Single Din Radio, with the cup holder removed
If everything works out correctly Ill be making at-least 5, in different designs and materials
2008 Evo X GSR
Old 09-18-2012, 04:28 PM   #8
Let me know, as I'd be interested in buying one if you go that route.
1998 900 SE- sold
1995 9000 CSE
Old 09-18-2012, 08:14 PM   #9
1995BlueBeast's Avatar
Sweet project! It should be really easy to have a larger piece of plexi and program multiple units per cut. Engineering school toys?
1995 900 SE Black on Black Coupe RIP 4/22/12
2002 9-3 Viggen Convertible Black on Tan
2000 9-3 Viggen Sedan Silver on Black
1995BlueBeast is offline
Old 09-19-2012, 04:44 AM   #10
mckpat03's Avatar
Good ole Inventor. Oh how I hate that program. Cool project, though.
'10 Jetta TDI Cup Edition - DD
'91 Talon TSi AWD - DD rally beater project
mckpat03 is offline
Old 09-19-2012, 04:52 AM   #11
Cark's Avatar
Hoping to put gauges in my 85 this winter. If this fits well in a normal DIN slot I'd be interested in one!
02 9-5 Linear turned Aero, 5spd S/C
85 900 turbo - T5ed (in a day)
Cark is online now
Old 09-19-2012, 09:08 AM   #12
yeah school toys.haha
6 hours out of my 8 hour day I'm a lab assistant but my teacher never has anything for me to do, so I just get to chill in the Technology Department and play with all sorts of cool stuff.
900 have bigger SID's I think, so I would need Dimensions if I did run a Batch of ones to fit in them
2008 Evo X GSR
Old 09-19-2012, 09:25 AM   #13
Cark's Avatar
Um, my 85 C900 has no SID... It has an upper DIN slot where the radio goes that I'd like to put gauges in. There is another DIN slot in the lower cubby that the radio can go in.
Cark is online now
Old 09-19-2012, 09:47 AM   #14
ohhh, sorry wasn't paying any attention to the year of your 900, my bad.
but it will be a different size from the ones im making. I'll get in contact with you after I make a few for 9-3's and Perfect my method along with finding the best material to use.
-Ben
2008 Evo X GSR
Old 09-19-2012, 10:31 AM   #15
turbocon86's Avatar
If you are mounting in the radio din on a c900 you need a faceplate and a backing plate with some mechanism to hold the faceplate into the din opening. The backing plate gets held to the faceplate by the gauge mounting bracket. I've done something like this in the past. the backing plate has tabs at the top and rotating tabs at the bottom. Hook the top tabs in and push the unit into the opening with the bottom tabs in the up position, and then when you turn the mounting screws on the front side, they rotate down to hold the unit in place. Tighten the screws down to hold it in firmly. If you need to take it out, rotating the screws on the front of the faceplate in the opposite direction turns the tabs back up to release the unit.
I just cut mine out of thick aluminum with a hole saw and a scroll saw. I'm sure you guys with the high-tech equipment could do a better job.
(This is not to scale, just the concept)
1993 900T Comm Ed #3
1993 900T Comm Ed #249
1994 900T Comm Ed #363
turbocon86 is offline
Old 09-19-2012, 11:29 AM   #16
You might find that 1/4" acrylic is thicker (and more expensive) than you need. It scratches pretty easily, too.
If you want to try other materials, I suggest a thinner polycarbonate (a.k.a. "Lexan") or some foamed PVC material (a.k.a. "Sintra"). Sintra is relatively cheap, really easy to cut, and has a nice forgiving matte finish.
Used Saab Parts:
dantinne is offline
Old 09-20-2012, 04:30 AM   #17
Like the project.
However, Inventor I despise. Can't tell you how many times I wanted to kill myself using that software.
SolidWorks ftw.
mustardtiger is offline
Old 09-20-2012, 07:53 AM   #18
dan-the-kid's Avatar
Originally Posted by mustardtiger View Post
Like the project.
SolidWorks ftw.
I need to learn.
Teach me the ways of your CAD.
dan-the-kid is offline
Old 09-20-2012, 10:22 AM   #19
When can we reasonably expect that your 85 will have a SID? I assume you'll be adding one soonish.
BuHuSPG is offline
Old 09-20-2012, 11:17 AM   #20
byastremski's Avatar
It'd be much better if you designed a pod like sleet had that mounts in the ash tray/cubby spot... bet you would sell 25-30 easy...
2001 Viggen BCB stg1
byastremski is offline
Human Verification
