spg panel rubber trim? who sells them? - The Saab Link Forums
Go Back   The Saab Link Forums > Saab Classic 900 Forum '78-'93 > Customizing Your Classic 900
Customizing Your Classic 900 This forum contains all CUSTOMIZING related Q&A's, such as Lights (taillights, headlights, turn indicators, clear corners, etc), Interior and Exterior modifications, Wiring, Gauges and more.
Old 11-20-2008, 06:28 AM   #1
900AERO's Avatar
and how close are they to the originals? i only need to replace the rubber trim on one door panel. so i want to find a good match.
WHATEVER.....SAAB'S ARE FASTER THAN WHAT YOU THINK.
900AERO is offline
Old 11-20-2008, 11:00 AM   #2
turbocon86's Avatar
Not available any more.
Which panel do you need the weatherstrip for? I just did mine with a modified off-the-shelf molding from an online supplier. It is made of rubber so it won't get stiff or brittle over time. I had to improvise a special tool to cut off the extra liitle bit that I didn't need for the SPG panel weatherstrip profile. It took a while to make the tool, it has to consistently cut the exact same amount off on every strip--no small task.
I just did my SPG panels I'm installing. It looks really good on the car. Very similar to OEM in size and shape. Jon Williams has used an off-the-shelf product that is readily available. I think that the profile is different enough from OEM that you'd have to do all the panels to match, and the door panels need a butt joint on them because the material comes in a fixed length that is a little short.
I've considered making up some SPG weatherstrip kits for sale, but the off-the-shelf molding is $3.50 a foot plus shipping. I don't think I could mark it up enough to make it worth my while.
I'll get up a pic of the molding on the car when I get a chance. Or you can see it at the NYSOC Adirondack Saab Run. I'll be there with the car.
1993 900T Comm Ed #3
1993 900T Comm Ed #249
1994 900T Comm Ed #363
turbocon86 is offline
Old 11-20-2008, 11:53 AM   #3
drewz airflow se's Avatar
I am looking for those pieces of rubber trim too.
^CLICK ME^
drewz airflow se is offline
Old 11-22-2008, 05:38 PM   #4
turbocon86's Avatar
Got the rest of my SPG panels and the wheel arches on the car today. I only had one mount strip with clips for the wheel arches so I had to improvise. I had some sheet stainless laying around so I made some custom-bent clips. I actually like them better than the OEM mount. They are easy to get on and align and they hold incredibly well. They also don't hold water along the wheel arch edge like the OEM mounting strip. I put some aluminum duct tape tabs on the fender under them so they don't scratch the paint.
Here's the clips:
Here's the clips on a wheel arch scrap I had laying around:
And here's the pics of the SPG weatherstrip I made.
Here's a comparison in cross-section of the off-the-shelf molding, the molding after I cut it, and the OEM panel molding:
Here's the molding mounted on an SPG panel with 1/4" 3M mounting tape:
Here's a couple pics of the tool I improvised to cut the o-t-s molding to fit:
Old 11-23-2008, 05:30 AM   #5
Trollerator
abdukted1456's Avatar
that's really good stuff. Might need some help with some molding
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 11-23-2008, 05:35 AM   #6
c900 Grognard
Jack Straw's Avatar
That's a clever tool, nice.
Originally Posted by IronJoe
Jack Straw is offline
Old 11-30-2008, 06:01 PM   #7
turbocon86's Avatar
At the Adirondack Saab Run yesterday I saw a nice '86 SPG. The car owner took Jon's advice and used the TrimBrite T4002 stick-on door edge molding for panel weatherstrip. It looks REAL nice and is WAAAY less expensive than what I used. I originally thought that the TrimBrite molding was "L" shaped and that's why I looked for another alternative. It is actually "T" shaped, and pretty darn close to the profile I got with my custom-cut molding. I think it's a little more rigid too, which is a good thing--you won't get a wavy edge. Jon told me if you superglue the seam that you have to put in the weatherstrip on the door panels, it's invisible. Wish I saw that before I went through all the trouble. Well at least there's a couple alternatives to OEM now.
Old 12-01-2008, 05:55 PM   #8
Green9kAERO's Avatar
i might need some of that trim too..... first i must reassess my panels and check.
JP
Green9kAERO is offline
Old 12-04-2008, 05:08 AM   #9
mike d's Avatar
My solution
my SPG panels had horrific stripping on them,, my solution was to use a type of windshield weatherstripping i had kicking around in the basement... the weatherstripping pushes between the panels and the body, and theres no need to even take the SPG panels off to fit it
install instrutions= start, cut to length, push between panel and body, end
hear are some pics of the outcome
i also could not get a clear pic of the side profile of the stripping, but here is a quick drawing to help illustrate
MikeDTuning.com
mike d is offline
Old 02-13-2017, 04:30 AM   #10
tuner4life's Avatar
Bumping this thread for my own interests later..
Trimbrite T4002 seems like a good option, but I would really like to see some pictures of it in use because the sellers pictures are terrible.
Also Turbocon86: Do you want to make another set of those fender arch mounting tabs? (I could probably make my own, but wasn't sure if you had a jig/die for them or something)
-Jason
1986 Saab 900 Turbo & 1992 Saab 9000 Turbo
tuner4life is offline
Human Verification
