the $500 9-5 project - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Customizing your 9-5
Customizing your 9-5 This forum contains all CUSTOMIZING related Q&A's, such as Lights (taillights, headlights, turn indicators, clear corners, etc), Interior and Exterior modifications, Wiring, Gauges and more.
Old 08-20-2011, 05:45 AM   #1
BALDSAAB's Avatar
Garage
I am going to start this project this sunday of tearing apart fixing problems and converting this thing to a 2005 aero clone... its a 2002 9-5 base with a 5 speed and 2.3 small turbo. My goal is to get this thing going and because I like the bed more than the couch I'm doing this on a budget. I will be doing the body work fixing normal odds and ends and finaly performance. so stay tuned and I will keep with the updates.....
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
2000 saab 9-3 vert jzw stage 5
1968 barracuda 340 sb SOLD
1972 nova 396 BB
2008 LINCOLN MKX ELITE
BALDSAAB is online now
Old 08-20-2011, 05:47 AM   #2
BALDSAAB's Avatar
Garage
ok forgot to give the back ground i grabed this for $500 from my old job it was traded in on new years eve and was in a light front end whack needs a hood two fenders and new bumper and front lights..... other than that car runs great and just needs some tlc.
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 08-20-2011, 06:55 AM   #3
bobg450's Avatar
Get a another cheapo 9-5 (same color) with a dead engine or rear end damage. Unless you can get all those parts cheap, you could easily spend another $500 or more. Then part out the donor car (a good V6 turbo alone is worth a lot) and get all your money back + $300 at the salvage yard. You could end up with a 9-5 for free! Or even make a few $$$.
Been there, done that, with a 2000 9-3SE. My 2c.
saabang2.jpg plus NewSaabs 002.jpg = $$$$ & FUN
"But taking a car to its limit is dumb if you go past your limit." a viggenlucaism
'00 VigVert- Nirvana
'00 9-3SE DD
'99 9-3 fixerupper
bobg450 is offline
Old 08-20-2011, 07:17 AM   #4
BALDSAAB's Avatar
Garage
All ready got the 05 Aero front and rear bumpers and scored the head lights for 100
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 08-20-2011, 07:19 AM   #5
bobg450's Avatar
cool. keep us updated. pics a must.
'00 9-3SE DD
'99 9-3 fixerupper
bobg450 is offline
Old 08-20-2011, 07:38 AM   #6
BALDSAAB's Avatar
Garage
im gonna attack it tomarrow i changed the oil last night i didnt think it was worthy of pictures ill pick threw it and make a list of issues any help here would be great and any 9-5 knowledge and of course parts..
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 08-20-2011, 07:47 AM   #7
kmbaer04's Avatar
Plan on doing a little modding to the exhaust, the cutout is different from '02-'03 and '04-'05. Unless you have the hidden tip, which you probly do, or your probly getting a new exhuast which you probly will.
'02 9-5 Aero 5spd ~Parting out
'08 9-3 Turbo X
'08 9-5 Aero ~Trading
kmbaer04 is offline
Old 08-21-2011, 06:21 PM   #8
BALDSAAB's Avatar
Garage
ok i took a good look at the car today and made of list of problems things needed and things to be tossed.....
problems
1. drivers front and rear window do not work.
2. sid and acc screen fail no suprise
3. all heat ac comes out of the top defrost and no place else help!
4. three broken DI screws help! drill and tap?
5. 2.3 t and not a 2.3T gt17 paper weight need a td04
6. shark fin looks like i put on a shirt from five years ago "shrunk"
needs
1. shark fin antenna
2. aero sides
3. aero fogs 2005 style round
4. corner markers
5. wheels factorys wont cut wondering how my steel gray aeros will lokk on it
6. a td04 or bigger
problems
1. WIFE another saab..... thank god for my quick wit and i bought her a new truck a coupple of months ago. problem solved i told her this would be hers to bring to shows and so on so we came to agreements on a blacked out aero clone with some power under the hood and maybee pink calipers ill talk her out of that down the road.
plans
i will probaly go with the same set up on the vert td04 and jzw tune
might be swaping parts from vert for a holset...
i will keep posting work and progress will be verry greatfull if any one can help with needed parts and help with problems listed above.
thanks all
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 08-22-2011, 02:08 PM   #9
BALDSAAB's Avatar
Garage
can anyone give me a hand on whats up with the heater on my car its only blows out the defroster vent even if you hit other buttons??
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 08-25-2011, 04:02 AM   #10
jssaab's Avatar
Door flapper problem it auto and on at the same time and read the codes in the ACC panel
jssaab is offline
Old 08-25-2011, 09:10 AM   #11
What jssaab said. It will most likely be an inexpensive fix, requiring a plastic part. Read the ACC codes by pressing auto and off at the same time. The codes will tell you what to pull apart to see where it needs fixing.
ji5mmy is offline
Old 08-30-2011, 09:43 AM   #12
Take out the stepper motor on passenger side and tap the shaft in on the rear side. The gears are not making contact. Been there done that. If when you are removing the motor you notice the plastic part has failed then that will have to be replaced.
rayodunne is offline
Old 09-23-2011, 01:57 PM   #13
BALDSAAB's Avatar
Garage
thanks guys its been buging me.
body parts are all done got front bumper rear bumper and two fenders painted for $300. picking up sat and will install new nose on my day off thursday ill take some pics. now i just need two corner markers and aero fogs also all the plastic lower grill peices for front and rear bumpers...
also im fairly new to the 9-5's what should i look out for??? 2002 2.3t 5-speed
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 09-23-2011, 03:39 PM   #14
BALDSAAB's Avatar
Garage
SAAB 9-5 heater door stepper motor repair kit | eBay
is this the thing to fix the heat and ac problem?
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 09-25-2011, 04:55 PM   #15
jssaab's Avatar
No that's not it
Check eeuroparts, but first see what's broken, if its jsut the arm its a 10 dolalr dealer part, if its the shaft too, eeurop has a repalcemtn shaft/arm
jssaab is offline
Old 10-21-2011, 05:34 PM   #16
BALDSAAB's Avatar
Garage
OK just drooped this off at the body shop ill take some pics when it gets back still need side skirts grills and corner markers......... any help LOL can't wait to get this on the road and save the 93 from the daily driver abuse.
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 11-11-2011, 01:30 PM   #17
BALDSAAB's Avatar
Garage
Allmost done some pics of it at the body shop still need corner marks and Aero fogs if any body has them let me know
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 12-05-2011, 01:32 PM   #18
BALDSAAB's Avatar
Garage
car 85% done just have to install the rest of the lower grills fogs and lights.
also have to re fit some pannels that dont line up correctly its on its way to be a linaero...
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 12-05-2011, 01:35 PM   #19
BALDSAAB's Avatar
Garage
sorry for the shitty cell phone pics
www.fmylife.com
WWW.METROFORDMA.COM
2002 saab 9-5
1972 nova 396 BB
Old 12-05-2011, 01:39 PM   #20
J-Rod's Avatar
Looks good!
I don't drive fast...I fly slow
2003 9-5 Arc
Originally Posted by Palmer View Post
He'll be back in a couple of months or something.
Then he's going to drive a car into my ass.
J-Rod is offline
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2012, vBulletin Solutions, Inc.
