P1444 - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > Car Problems? NG900 or old 9-3 Only
Old 04-27-2012, 01:47 PM   #1
WSW
WSW's Avatar
P1444
Canister close valve open/short to ground
Where is this valve located? I typed in the code on WIS and its not popping up
Any help would be greatly appreciated
99 Viggen
91 9K
WSW is offline
Old 04-27-2012, 01:57 PM   #2
DrewP's Avatar
It's about halfway up the fuel filler neck, remove right rear wheel to access it through the wheel well.
"You can educate ignorance, but you can't fix stupid."
Los Angeles Saab Club
DrewP is offline
Old 04-27-2012, 02:10 PM   #3
WSW
WSW's Avatar
What would be the best way to go about diagnosing this code?
99 Viggen
91 9K
WSW is offline
Old 04-27-2012, 02:19 PM   #4
ohms check from ecm pins to canster close valve pins, should be .3ohms or less. then ohms check pins to ground, should be out of limits. Make sure ecm is disconnected from the wiring harness during diag. If wiring checks good replace valve.
Drifting-FB is offline
Old 04-27-2012, 02:27 PM   #5
DrewP's Avatar
Check the valve first - it's much easier. There should be continuity across the two pins, when you power one and ground the other (doesn't matter which for either of them) the solenoid should click, and the valve should close.
DrewP is offline
Old 06-19-2012, 08:11 AM   #6
WSW
WSW's Avatar
Replaced the valve And nothing has changed
99 Viggen
91 9K
WSW is offline
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
