This one has me stumped, noise on throttle let off - The Saab Link Forums
Old 08-16-2011, 05:08 PM   #1
kalvinr11's Avatar
Hello folks,
It has truly been a while since I have posted here in any capacity. Everything works great, which is exceptional for 181,000 on the clock. Here's the one strange thing:
On throttle let-off, in any gear, and not every time, I get a "hooting" noise. The noise usually does not happen after a hard acceleration, instead it shows up on light throttle lift-off before gear changes. It is obviously related to the dump valve. I replaced the dump valve, as I had the MIL come on and a code specifically for it. I figured that would fix the hooting. I was wrong.
The noise is still there. I have checked all the vac lines, smoked the intake system and checked the operation of the new valve. Everything is good.
Ideas?
-Mike
'99 Viggen with 205k
Status: Mostly OK and studded winter tires
kalvinr11 is offline
Old 08-16-2011, 05:15 PM   #2
Legit's Avatar
How are your vacuum lines? Especially the one coming off the dump valve
2002 Viggen Convertible
Legit is offline
Old 08-16-2011, 08:31 PM   #3
srp
srp's Avatar
Send a message via AIM to srp
Have you done the T7 bypass mod?
T7 Turbo Bypass Valve Mods – TrollTuner
srp is offline
Old 08-20-2011, 01:13 PM   #4
kalvinr11's Avatar
Vac lines are good, not original but definitely not new. They hold vacuum fine.
I have not done the bypass mod. The hooting sounds exactly like what I'm experiencing. Thanks SRP, I've never heard of that. I'll try it out this coming week.
-Mike
Old 09-12-2011, 02:08 PM   #5
kalvinr11's Avatar
I did the bypass mod today, the noise is 100% worse than before. On every throttle let off, whether after WOT or easing off, the noise happens. When giving it a little gas, and then backing off quickly, the noise also happens...Everything else is tight and the CABV is new.
-Mike
Old 09-12-2011, 03:16 PM   #6
Greek Mod
grkguy89's Avatar
factory valve or aftermarket?
Current Activity: Moderating
grkguy89 is offline
Old 09-15-2011, 04:47 PM   #7
kalvinr11's Avatar
Factory Bosch valve. I thought about getting the Forge valve but couldn't justify it with our current budget and its outlook.
I had a buddy of mine ride with me last night to listen to the noise. He says it's less of a hooting noise and more like a weird sounding horn. The noise starts off "up front" but then sounds like it "takes up the whole car." I think I may swap dump valves with another friend who has an '01 9-5 Aero to see what that does. His car doesn't sound like a fog horn.
-Mike
Old 09-15-2011, 06:12 PM   #8
PimpMyPc's Avatar
The stock valves wear and get pretty loose. Mine started hooting at ~162k at part throttle, used Forge BOV (BPV in your case) fixed it up nicely.
PimpMyPc is offline
Old 09-17-2011, 06:00 PM   #9
kalvinr11's Avatar
The dumb part about this is the Bosch valve is new, about one month old. I'm going to smoke the intake again this week as it's been a few months since the last time.
-Mike
Old 09-18-2011, 04:54 AM   #10
lms
Flip the diverter to see if it changes any. How old is the turbo, and are you running the diverter like a BOV by any chance?
lms is offline
Old 09-19-2011, 08:12 AM   #11
kalvinr11's Avatar
Turbo is original, almost 182k miles. I'll try flipping the valve around, see what happens. The car is basically stock aside from poly engine/trans mounts. No BOV as it's T7.
-Mike
Old 09-20-2011, 08:59 AM   #12
bergie's Avatar
give me a call if you want, i saw your car the other day while i was at majestic motors btw, ill take a look at it for you, 6033911409.
bergie is offline
Old 09-20-2011, 03:37 PM   #13
kalvinr11's Avatar
Thanks man, I'll be going over it again at work this week and see if I missed anything. It's frustrating when you can't fix your own car but you can fix everyone else's.
-Mike
Old 10-02-2011, 07:30 AM   #14
ScandinavianRocketng900's Avatar
My stock bosch started to make pretty similar noise anytime it was closed and somtimes when it opened slowly, I thought is kinda sounded like a whale, but anyway, i replaced it with a Forge and fixed it and it seemed to hold boost better as well.
1997 900 se turbo
1995 9000 Aero
2002 93 se
ScandinavianRocketng900 is offline
Human Verification
