bleeding the clutch on the viggen - The Saab Link Forums
Old 12-24-2010, 03:21 PM   #1
The Saab LB's Avatar
hi everyone i went to bleed the clutch on my viggen and the peddle wont come up now can i get some help ill appriciate it thanks and happy holidays.
The Saab LB is offline
Old 12-24-2010, 03:24 PM   #2
stromer's Avatar
Sounds like you need to keep bleeding...
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 12-24-2010, 04:01 PM   #3
i bled it for an hour and half and still nothing dont know wats up.
Old 12-24-2010, 04:38 PM   #4
Grab the pedal by hand, pump the hell out of it, top off fluid, open bleeder (pedal up), walk away for 10 min, close bleeder. Repeat as needed. Best success I ever had with a ng, 9-3, 9-5 was gravity bleed
seriks1 is offline
Old 12-24-2010, 05:15 PM   #5
i tryed that and no go
Old 12-24-2010, 06:36 PM   #6
really these cars are very hard to bleed without a vacumme or pressure bleeder. if you have air into the slave now im pretty sure you are screwed because that really needs to be bench blead is my understanding. when i installed my clutch it was bench bleed the slave, install trans and vac bleed a couple times and presto.
99 lb viggen
dcr99vig is offline
Old 12-24-2010, 06:38 PM   #7
or your booster/slave may be screwing up, not anywhat sure on that without more info?
99 lb viggen
dcr99vig is offline
Old 12-24-2010, 07:18 PM   #8
DanF.'s Avatar
I use a screwdriver and lever the slave cylinder a few times. It will force the air out of the open bleeder valve.
1986 900S wrecked
1987 900T wrecked
1988 900 SPG sold
1987 900T parts car
1987 900 SPG parts car
1991 900T sold
1997 9000 Aero sold
2004 9-5 Aero sold
DanF. is offline
Old 12-29-2010, 07:46 AM   #9
Take a piece of wood and a clamp and use them to keep your clutch pedal pressed down overnight. That will let the air work its way out of the line. I've done that twice and it worked perfectly both times. The last time I bled my clutch, I was lucky enough to get a reverse pressure bleeder. That got the clutch working on the first try in about 5 minutes. If anyone runs across a MityVac Hydraulic Injector System Shooter, buy it!
Jeremy R. is offline
Old 12-29-2010, 08:11 PM   #10
Makeyousaab's Avatar
you really need to do this with a pressure bleeder.....it is just how they are made. Once air is in the system you are SOL.
if you are resourceful you will find another way to apply constant pressure to the brake fluid reservoir....I managed to use the plastic cap that seals a gas container, which i drilled a hole into, then put in a tire valve stem.
......good luck!
~Dave
Makeyousaab is offline
Old 12-30-2010, 05:45 AM   #11
hi everyone thanks for all the info sorry for getting back asap but i applyed pressure on the resovoir and also was used a vacuum bleeder and still nothing then i removed the panel by the padles and noticed some fluid coming out of the master cylinder. thanks again everyone.
Old 12-31-2010, 08:18 AM   #12
That's not good! RockAuto's the cheapest place to get a new master cylinder. It comes in a Dorman box, but it's made by the same German company that makes the original.
Old 01-01-2011, 04:15 AM   #13
thanks jeremy.
Human Verification
