Window off track. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > Car Problems? NG900 or old 9-3 Only
Old 04-13-2009, 05:55 AM   #1
someguy's Avatar
Send a message via AIM to someguy
Window off track.
Ok, so I was in DC this weekend and went to put the passenger side window down and it fell off its track. I was able to force it into the up position and lock it in place by putting the window motor all the way up.
Anyways I haven't had a chance to take the door apart yet as I just got home from my trip last night, but is this going to be a major thing to fix? Is this fairly common?
What's the likelihood that something is actually broken to where I need new parts?
Thanks in advance.
President and Founder of the NJSA- "We bring nothing to the table."
1999 M3 Cabrio
someguy is offline
Old 04-13-2009, 06:00 AM   #2
soccerrplyr's Avatar
most likely its the 7 dollar plastic piece wheel that goes in the track to raise/lower the window. Pain to fix but cheap and easy
File Type: jpg md_d2ee92cc-4af8-41d0-ae80-b3eb0cefc099.jpg (2.7 KB, 47 views)
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 04-13-2009, 06:09 AM   #3
NahumCC's Avatar
More than likely what has broken are one of the little green window rollers in the track.
Pulling the door card off is easy. Have it open and then do the following.
1. Pull off outer half of door pull and unbolt the two torx screws hiding there.
2. Remove the trim cap hiding behind the door release lever and unbolt the torx and then pull out that release lever.
3. On the back of the door jam that seals with the car body you'll see a plastic pop rivet. Take the tip of your torx and push in the center. Once pushed in just pull it out by getting your finger nails on the outer edge.
4. At the bottom of the door card will be two torx going into the door threw clips attached to the door card; remove them.
5. Remove the plastic trim that sits on top of the door card where you would have your side mirror adjust buttons if we were a RHD market. Just pull it off. It takes a bit as they snap in there real tight but don't worry about it.
6. Pull the door card off. Be careful as you pull it off as you will have to slide the card up and over the door lock indicating stub other wise if you just yank you'll damage the metal rod its attached to. It's [door card] on there good and tight with some plastic parts that go into the door body. Just work you way off slowly.
7. Pull back the foam water/sound sealing and have a look around at your window track and find the broken roller. Remove any part left of it (likely just the metal clip and the center of the roller).
8. If enough grease is in the track still slide in the new roller (without the metal clip) and get it in the grease otherwise you'll need to lube it up first.
9. Raise the window up or down to get it in a position to where you can snap the window rod back into the roller and your done. Just put it all back together.
Edit: Soccer beat me to it while I was writing a how to. But those are the little buggers your looking for.
2013 FR-S
NahumCC is offline
Old 04-13-2009, 06:15 AM   #4
someguy's Avatar
Soccer, thanks for putting me at ease with this.
You, Sir, are great. Thanks.
1999 M3 Cabrio
someguy is offline
Old 04-13-2009, 06:38 AM   #5
NahumCC's Avatar
No problem. Its an easy job. Have a beer or two while you do it.
2013 FR-S
NahumCC is offline
Old 05-05-2009, 10:25 AM   #6
someguy's Avatar
Update:
I attempted this two weeks ago after only ordering one window roller. Took it apart to find I needed two.
Last Saturday I took it apart again, got one to seat property then managed to break the green part of the other one while putting the clips on (oops).
Just ordered another and a spare today! Found out Amazon has these, so being a Prime member I get free shipping. I'm really just starting to accept that I will never have a working passenger window again.
1999 M3 Cabrio
someguy is offline
Old 01-01-2010, 08:35 PM   #7
guru's Avatar
Does anyone have a link to where I can order these puppies on Amazon? Black900 just called to tell me my window "fell off" and now I probably need to replace them.
guru is offline
Old 01-01-2010, 08:55 PM   #8
someguy's Avatar
http://www.amazon.com/Scan-Tech-Prod.../dp/B001G5Y054
I may have two of these that you can have. I'll have to check though.
1999 M3 Cabrio
someguy is offline
Old 06-03-2013, 05:11 PM   #9
follow up question
does this work for a 04 9-3 saab?? or is there something else to do?? my saab window is stuck in the up position. the dealership wants $700 and they say that i need to replace the entire motor so i went online and found this discussion and im hoping that i dont need to spend that much and that there is an easy fix for it. please help or direct me to somewhere that can!!
krhodes425 is offline
Human Verification
