Rear Hatch Area Water leak-Solution! (maybe sticky this one) - The Saab Link Forums
Go Back   The Saab Link Forums > Saab NG900 94-98 and 9-3 99-02 Forum > Car Problems? NG900 or old 9-3 Only
Old 09-10-2008, 07:38 AM   #1
bobg450's Avatar
Slayed another dragon! Maybe half of the visitors to this website have already figured this one out, but here goes:
Water leaking into the right rear corner of the trunk has plagued me on my
'95 and '97 900SE's. I used to think it was coming from the hatch or the sun roof drain (possibly clogged and frozen/cracked) or the fixed side window behind the rear door. It comes from the area of the large grommet around the fill tube. There is a nipple on the grommet that locates it into a hole in the sheet metal. Unfortunately,this hole is on the bottom and the 1/2" or so of water that accumulates there will drain down into the interior of the trunk if the nipple has deteriorated. I fixed it with some Blue Permagasket I had, but any good gas resistant RTV should do.
bobg450 is offline
Old 09-10-2008, 07:49 AM   #2
mcrowley's Avatar
Got a picture of what exactly you're talking about?
I've had issues with water in the trunk of my 900. Got new rubber drains for the roof, resealed the rear windows, new taillight seals, etc...still get a bit of water in there.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-10-2008, 07:51 AM   #3
I have this issue on my Vig.
It's on my to-do list to investigate and fix. Judging by the location on the right hand side corner of the trunk, I would think its the same cause.
Jameson is offline
Old 09-10-2008, 08:47 AM   #4
srp
srp's Avatar
Send a message via AIM to srp
I have the rubber all season mat in my trunk. After a hard rain there will be some drops on top of the mat in the rear rigght corner. There is an opening in the side panel directly above that wet spot. Must be running down from somewhere...
srp is offline
Old 09-10-2008, 09:47 AM   #5
NahumCC's Avatar
Oh I'm so very interested in pictures of this. I'm getting tired of during the summer after lots of rain on the first nice day of pulling the entire hatch contents out and leaving the gate open to dry out.
2013 FR-S
NahumCC is offline
Old 09-10-2008, 10:47 AM   #6
Deez Nutz
Palmer's Avatar
Oh, hi.
Same issue.
Pictures would be neato.
TDi/JKU/330i
Palmer is offline
Old 09-10-2008, 10:52 AM   #7
aireeca's Avatar
Count me in, too. Crazy cars.
aireeca is offline
Old 09-10-2008, 12:26 PM   #8
bobg450's Avatar
Water Leak
Like I said, I can provide a picture, but, remove your gas cap and pull out the plastic shield on the filler tube. There is a rubber seal that goes around the filler tube. Lift it up at the lowest point and you will see the little rubber "piton" (french) that goes down into the hole in the sheet metal. If you want, put on your gas cap, pour a shot glass, or 4 fingers, of whatever you want your trunk/hatch area to smell like. Watch it slowly go down. It ain't going into your gas tank or onto the ground. Now dry out the area and put a good gas resistant RTV (in case your one of those who insist on filling your tank to the tippity top) around the bottom half of the rubber seal where it interfaces with the sheet metal, especially in the area of the "piton". Voila!
bobg450 is offline
Old 09-10-2008, 12:29 PM   #9
Deez Nutz
Palmer's Avatar
Awesome.
Maybe I can take some pictures tonight.
Thanks for the info!
TDi/JKU/330i
Palmer is offline
Old 09-10-2008, 02:43 PM   #10
mcrowley's Avatar
I see the plastic shield on the top of the filler tube...only problem is how do you get it out? Its not exactly loose or easy to pop off. Whats the trick?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-10-2008, 02:43 PM   #11
Deez Nutz
Palmer's Avatar
I'm going out right now.
Will report back.
TDi/JKU/330i
Palmer is offline
Old 09-10-2008, 02:49 PM   #12
aireeca's Avatar
Will report back.
Good luck and god speed!
aireeca is offline
Old 09-10-2008, 03:17 PM   #13
drewz airflow se's Avatar
I dont have this problem with my ng fortunately.
^CLICK ME^
drewz airflow se is offline
Old 09-10-2008, 03:18 PM   #14
Deez Nutz
Palmer's Avatar
You must pry:
(don't worry, I put a pad under the screwdriver)
Then you see this:
Then when you lift the gasket:
See next to the screwdriver blade?
Back of the ring so you can see where the clips are:
(the small ones go on the bottom)
...please ignore the dirt...
TDi/JKU/330i
Palmer is offline
Old 09-10-2008, 03:24 PM   #15
mcrowley's Avatar
Palmer rules.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-10-2008, 05:47 PM   #16
bobg450's Avatar
Water Leak
Thanks Palmer. Now what else needs fixin? My sunroof glass only goes up on one side when closing. Think I'll go to the junkyard and tear one of their Saabs apart to see what makes that sunroof "tick".
bobg450 is offline
Old 09-10-2008, 05:50 PM   #17
Deez Nutz
Palmer's Avatar
No problem!
It's a common issue, so nice work!
...I also cleaned out that area on my car. I could not take it.
TDi/JKU/330i
Palmer is offline
Old 09-15-2008, 03:25 AM   #18
mcrowley's Avatar
Had a decent amount of rain here in NY this past Friday. Two taillight seals, new sunroof drains, plus sealing the filler neck and my trunk finally stayed dry!
Time to get some new carpet.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-16-2008, 05:37 AM   #19
nowhereman's Avatar
Dude you rock. i now know where that horrilble water is coming from. YAY!!!!
and palmer you rock for the pictures. i know what I will be doing tonight.
2008 9-3 SS: Stg 1
nowhereman is offline
Old 10-05-2008, 10:26 AM   #20
t@llpum@'s Avatar
Wow, I didn't know this was such a common issue.
Thanks for the solution and photos.
Come to STL and buy all (well most) my Saab's and take them away on a semi...please
t@llpum@ is offline
Human Verification
