Help - Saab Warning, Gearbox malfunction limited performance. Contact saab. Does any - The Saab Link Forums
Go Back   The Saab Link Forums > Saab New 9-3 '03+ Forum > Car Problems? New 9-3 Only
Car Problems? New 9-3 Only If you're experiencing problems with your new 9-3 post your questions in here. CEL Code or GTFO!
Old 09-13-2006, 07:21 AM   #1
skos's Avatar
Help - Saab Warning
Does anyone know what this is? It just came on this AM, car only has 14K miles
skos is offline
Old 09-13-2006, 07:46 AM   #2
8valvegrowl's Avatar
Please don't double post, please go back and remove the thread you placed in the website problems section.
Now I know you have a 9-3SS, and I assume an autobox. Only thing to do is to take it to the dealer and have them read the code with a TechII scan tool. Maybe you have a small tranny leak and the fluid got low, hard to say.
Good luck and keep us posted.
8valvegrowl is offline
Old 09-13-2006, 10:45 AM   #3
1quick2.0t's Avatar
Originally Posted by skos View Post
Help - Saab Warning
big problem with aoutos falty radiators, the part that is trans cooler goes bad and mixes with coolant which gets sent back to the trans and then bam trans goes out, have it checked out asap
*Removed due to immaturity*
94\" 9000 Aero
3\" catless downpipe,Intake,3\" custom exhaust,H&R springs,Jak Stoll Stage 4 ECU,Clutch Net Carbon Ceramic Clutch plate, HKS EVC boost controller.
94\" Z28
383(9:1) afr heads,YSi,TH400,9"(it gets out of its own way ok
1quick2.0t is offline
Old 09-13-2006, 03:00 PM   #4
soccerrplyr's Avatar
Same thing happened to my friends aero, it was a sensor.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 09-13-2006, 03:06 PM   #5
swdmus's Avatar
Send a message via AIM to swdmus
Should be under warranty take it in
PRC Installations
1994 900SE 2.0L Turbo
1991 900S 2.1L
1998 Jeep XJ
swdmus is offline
Old 09-13-2006, 06:10 PM   #6
BurnsSide42's Avatar
input rpm sensor 9 times outta 10
Original TSL Founding Member
Check out
for your repair needs
BurnsSide42 is offline
Old 09-14-2006, 07:10 AM   #7
1sweet2.0's Avatar
Send a message via AIM to 1sweet2.0
I dunno... a guy I work with has a linear.. and he's been through 3 transmissions!!! those auto's are no good.
1sweet2.0 is offline
Old 09-20-2006, 05:17 PM   #8
Don't worry most likely is just a stupid sensor. I swear all those messages on the sid display i think are used to scare customers. I havn't really seen any major problems at my shop with 9-3 trans.
2nedEG is offline
Old 10-06-2006, 07:25 PM   #9
Angry Gearbox Malfunction
Well, I hate to be the bearer of bad news...I have had five gearbox malfunctions in three months. All of which left me stranded somewhere as the car just died. Limited performance basically means you have about five miles and then you're done! I have been very upset. At first it was sensors, and the local SAAB dealer somehow made the mistake of putting in the same bad snesors, how that happens beats me. I have been so disappointed with this car. I have only owned it 11 months. My parents have always driven SAABS and they tended to be on the very reliable side so I thought I would be safe and I think I leaning a different way now.
alexis luckey is offline
Old 10-18-2006, 04:35 PM   #10
infamous's Avatar
Sorry to hear of your misfortune with your new ride.
The only thing that pops into my head, alexis, is a problem that has presented itself on a number of occassions, i.e., have a look at your transmission housing/the electrical connections that you can see on it and see if there's any crud (grease/oil) build-up on them that could contribute to a faulty connection..., the connectors themselves could also be loose from the stealership in there tinkering with shit, and it does'nt hurt to check.
Another possibility occurs to me..., it could just be that you're a hott girl and the stealership likes having you come in so that they can watch you walk in, and out, to make their day..., who knows, but since you've had repeated issues with the tranny and you've only patronized the one dealership, perhaps it's time you sought out an "indie", or another stealership (I'm sure that the peeps here could point you in the right direction)"?"
Good luck with that and I hope that you're Saab experience gets better for you.
- Lacks proper social etiquette -
*stickied member*
infamous is offline
Old 10-18-2006, 07:22 PM   #11
I am so happy to say the problem has been fixed! Luckily, I don't drive much and the car was still under warranty. They put a new transmission in as well as a new radiator and made TONS of cosmetic repairs. Also, I'm not sure if anyone else has the problem, I've seen lots of cars with this, but my outside door handles were turning white, I took it in and asked if it would be covered under warranty and sure enough they replaced ALL of them. I am very happy with INDY SAAB and will totally continue to take my car there even after the warranty. They had the car 9 days and it came back to me like a brand new car!
Old 10-18-2006, 07:27 PM   #12
Reading stuff like this makes me not trust the 9-3SS platform. My dad was torn between the new Combis, the 5 or the 3, I tried explaining that the 5 would be the more sorted platform with less bugs. Replacing trannies? Hell no.....9-5 it is.
Jameson is offline
Old 10-18-2006, 07:30 PM   #13
iwantaviggen's Avatar
yeah i hear ya jameson..
manual 9-3 combi ok
auto yeah right i wouldnt even test drive one...
iwantaviggen is offline
Old 10-18-2006, 07:31 PM   #14
I'm by no means the first, there have been many, and ALL 9-3's and all I have heard of so far either 2003 or 04. The problem is coolant leaking into the tranny. However, SAAB was great with fixing the problem in the end and that's all I care about. The new tranny comes with an extended warranty and I'm pretty confident the problems are done.
Old 10-19-2006, 12:25 AM   #15
infamous's Avatar
If this is all that it was, it can be easily remedied by plugging/capping off the radiator's inlet fittings and installing a stand-alone, satellite cooler (like some of the old C900's had) on the lines off of the trans. housing (which is what I did with mine).
It's was less expensive than all of the (unfortunate) B.S. you and others had to go through..., but no one listens to me, afterall, it's not like I know what I'm talking about.
Glad to here that it's all fixed and that you're Saab happy again.
*stickied member*
infamous is offline
Old 10-30-2006, 05:01 PM   #16
spgproject's Avatar
that is not a saab factory repair. perhaps if the car was out of warranty some independent could rig up something like that, but dealers do factory repairs with factory parts.
-Sir William Lyons
spgproject is offline
Old 10-30-2006, 09:56 PM   #17
infamous's Avatar
Yes, the "dealers do factory repairs" with the same (faulty) "factory parts" that were the root of the problem to start with..., oh well, you can't beat a "warranty" repair, now can you?!
Just keep my tip in mind for future reference when the uh, "warranty", runs out, and hope that it's not at the same time that the problem develops again.
*stickied member*
infamous is offline
Old 11-08-2006, 10:08 PM   #18
Send a message via AIM to kelly Send a message via MSN to kelly Send a message via Yahoo to kelly
Its an official recall now I believe....
kelly is offline
Old 06-01-2009, 12:44 PM   #19
I was really dissatisfied by this car and I had to sell it.
I am Previous Saab owner i had the 2004 9-3, but unfortunately i had to sell it because of the problems that came with this beautiful car.
Most important one was the "Gear box malfunction". the problem started after 8 months of owning the car. i took it to the dealer more than 8 times on different occasions due to the same problem every time they fix it and it goes wrong again. They installed a new gear, new sensors but again the same problem kept happening
my parents used to drive a saab long time ago and never had a problem with it. i guess Saab's started to come with all those defaults after being soled to GM
Vampish is offline
Human Verification
