Steering Lock Malfunction - The Saab Link Forums
Go Back   The Saab Link Forums > Saab New 9-3 '03+ Forum > Car Problems? New 9-3 Only
Car Problems? New 9-3 Only If you're experiencing problems with your new 9-3 post your questions in here. CEL Code or GTFO!
Old 12-07-2016, 04:08 PM   #1
2004 9-3 ARC
Replaced battery.
When completed message appeared. Steering Lock Malfunction. Key would not turn, steering remained locked. Key will lock and unlock doors electronically.
Advice?
Erling Birkland is offline
Old 12-07-2016, 08:11 PM   #2
Wagon Shaggin'
Saabeh's Avatar
I don't know much about 9-3SS, but I will move this to the right forum so people can see it!
Saabeh is offline
Old 12-08-2016, 06:12 AM   #3
Turbo00's Avatar
If you replaced the battery in the car (not the key battery), and you're still getting the error then it's one of two things, either the ignition switch (about $100) or the 'central integrated module (CIM), which is the collar that goes around the steering column (about $500). Ignition switch is pretty easy to replace, just have to pull the console trim off around it and swap it out. If it's the CIM, then the steering wheel has to be pulled and the new CIM has to be coded to the car.
Turbo00 is offline
Old 12-09-2016, 06:09 PM   #4
Thanks for the information. Any idea why the components would fail with the replacement of the car battery?
Old 05-29-2017, 04:08 AM   #5
Hi I have recently purchased a Saab 9-3 sport wagon 2007 since buying it I have had 2 problems 1: the key unlocks all doors apart from the drivers door 2: it is now coming up with a message sterling lock malfunction make safe stop it will not let me turn the key or the wheel any ideas?? Thank you
Cropper09 is offline
Old 05-30-2017, 04:18 AM   #6
Turbo00's Avatar
Not sure on the drivers door remote unlock issue, but steering wheel interlock can be a few things, in order of severity:
1) Old/dying battery. Low voltage causes all sorts of screwy symptoms in these cars, so check this first/make sure you're up around/over 12.5V at cold start.
2) Ignition switch (https://www.eeuroparts.com/Parts/284...itch-12801010/) these are pretty easy to swap out and no need for a tech2 reprogram etc.
3) CIM (Central Integrated Module, https://www.eeuroparts.com/Parts/500...-CIM-12847563/). These are a bigger deal to replace and are more expensive/have to be coded. This is the collar around the steering column behind the wheel where the wiper/switch stalks mount, and also where the interlock is. Ultimately this is what went bad on my wife's old 08 9-3.
Turbo00 is offline
Old 06-05-2017, 08:23 AM   #7
Steering wheel lock malfunction
contrary to what this message should be implying, I have the message but can turn the key, turn the wheel and actually drive the car! Apparently I'm having issues with SID.
Any thoughts on what could be causing this?
dukewats is offline
Human Verification
