| Register | Garage | Photo Gallery | FAQ | iSpy | Members List | Social Groups | Search | Today's Posts | Mark Forums Read |
| Car Problems? 9-5 Only If you're experiencing problems with your 9-5, post your question in here. CEL Code or GTFO! |
LinkBack | Thread Tools |
#1 |
Heater Not Blowing Air
So today on the coldest day, the blower on the heater just stopped working. I checked the #22 fuse and its fine and also did the Auto/Off diagnostic and at first it gave me a 0 then I got 1 on the drivers side and 6 on the other. The heat still seems to be working just no blowing, What to try next?? Thanks
BTW its a 2000 9-5 V6 |
| Sponsored Links | |||
Advertisement | |||
#2 |
You have One code: (6) Stepping motor, air-mixing flap, LH Open circuit, short to B+ or short to ground B2490
ACC Fault codes | Saab 9-5.com Which is #23 on the left side of the diagram on eeuro. eEuroparts - Search Results You can get to it by these instuctions 1-3 12.10.2009: Saab 9-5 Blend Door Repair - photo.platonoff.com After it's out, well you'll have to research that on your own. |
#3 | |
M00 9-3 Conv. B234 makes up for Sun Green M73 99L In Maine |
#4 |
Thanks to both of you. They both seem like fairly simple fixes...lets hope I don't need a new motor. Yikes! If not for just the cost, I don't want to have to pull that damn thing out. Going to try the cracking of the sunroof while lighting candles and chanting right now.
#5 |
Ok so got under there and thought I would try something. I pulled the rod out of the second lever (the upper one its yellow on the passenger side) then the fan started to blow again, just until i turned the car off. When I turned it on again no blowing. So I am assuming it has something to do with that lever, but I got to it and it looks fine. Any ideas??
#6 |
Now I am thinking its a short somewhere because I drove it today and it randomly came on and stayed on a few times while being disconnected from the lever and rods. Also moved the pieces around and it started the blower. Interesting stuff. I'm not sure how to ground it, but I guess I'll look it up.
#7 |
Not a short carl is right probably bad bushes in the motor.. you can buy generic ones and repalce them, there is a thread here ( or on saabcentral)
#8 |
Alrighty gonna try for the brushes soon...luckily its warm right now. Any suggestions on how to get the wipers off I hear they are pretty tough. Anyone use a puller?
#9 |
Just a Heads up it was the blower motor, luckily found a fella on craig's list parting out and got it installed for $100. Now I have heat. Thanks for the help, but I have a new problem now. I guess I will start a new thread.
| Sponsored Links | |
Advertisement | |
| Tags |
| blowing, heater |
| Thread Tools | |
