Car died, no power at all. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Car Problems? 9-5 Only
Old 10-11-2010, 05:50 AM   #1
My sons 2000 9-5 2.3 had shut off on him a few days ago.
He started it, backed out of a parking spot, put it into drive and the car completely shut off.
He put it into park, and restarted it, the ACC system restarted (showing O), and drove it home with no more issues (5 miles).
Today while checking it out, I was able to get the ACC system to restart by turning the ignition off and on a few times, I could start the car and it would run fine.
I let it run for a while, and then went to park it, when I moved the shifter from Park to Drive, the car shut off, no electrical power at all to the car at any position of the ignition switch.
Waited a bit and it now works normal and starts right up, any clues?
The Alternator and Battery have been replaced and are functioning properly.
gbest is offline
Old 10-11-2010, 05:57 AM   #2
BurnsSide42's Avatar
Automatic? Sounds like a neutral safety switch going bad. This is a VERY common failure on 2001MY - but also will fail on the rest, just not as common. Do all the lights turn on with the key, but it does not click or crank when it acts up? I assume it's an automatic?
Neutral Saftey Switch (NPN Switch)
Part # 5256060
http://www.eeuroparts.com/Main/PartD...spx?id=5256060
Original TSL Founding Member
Check out
for your repair needs
BurnsSide42 is offline
Old 10-11-2010, 06:18 AM   #3
You will know for sure if it is the NSS by turning the car to the on position, but not turning the car engine on and moving the gear selector back and forth 5 or 6 times somewhat quickly...if it works fine for a while, this is the problem...shifting back and forth from top to bottom will clean the contacts off...you should replace the part soon though...this is an old Volvo trick.
cking1975 is offline
Old 10-11-2010, 06:26 AM   #4
That "old Volvo" trick does not always work on Saab's however - it's a hit or miss temp fix. Usually it works like banging on the fuel pump does for a bad pump - works a few times if you're lucky - but eventually it's just going to be dead.
Check out
Old 10-11-2010, 06:55 AM   #5
Yes, automatic.
When it shut down, it was dead.
No lights on the dash, no clicks from the starter.
Turning the key did nothing, just like the battery was disconnected.
gbest is offline
Old 10-11-2010, 07:12 AM   #6
Be sure to inspect the battery cables then - you could be getting lots of resistance from a corroded or loose cable dropping the connection. I'd be looking at that first. Then the ignition switch below the ignition cylinder.
Check out
Old 10-11-2010, 07:24 AM   #7
The cables appear to be OK and are tight, what specifically should I be looking for?
gbest is offline
Old 10-11-2010, 02:37 PM   #8
Success??
I just checked everything again, this time I followed the smaller positive cable to the maxifuse holder, took off the cover and found the nut that holds the 2 cables there was loose, not even hand tight.
I cleaned the connections and tightned the nut.
Do you think this was the whole problem?
gbest is offline
Old 10-11-2010, 05:59 PM   #9
mySaab900's Avatar
Send a message via AIM to mySaab900
that might have been the problem, but I would agree with the NSS theory. It also sounds a little like a CPS (crank positioning sensor). But usually the CPS shuts the engine off at highway speed, not just parking lot speed. Just another theory.
-Sean
'91 Saab c900 N/A (RIP)
'03 Saab 9-3 2.0t Arc
mySaab900 is offline
Old 10-12-2010, 05:16 AM   #10
I think the CPS is more a temp based symptom rather than the speed of the car...usually the faulty CPS shows signs of failing when attempting a warm start...there is only one way to tell, drive the car and see if the problem goes away...
Old 10-12-2010, 08:54 AM   #11
Thanks for everyone's help.
My experience with the NSS and CPS is they can prevent the car from starting/running, but have no relation to a complete power drop where nothing works.
The car ran fine last night, and my son drove it to school this morning, no phone call yet so hopefully it's solved.
gbest is offline
Human Verification
