D.I or not to D. I (misfire) - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Car Problems? 9-5 Only
Old 10-08-2009, 08:59 PM   #1
Sev7n007's Avatar
I have had this misfire issue for about two weeks. I pulled the plugs and found black soot all over them ( they where brand new by the way maybe two weeks old before this misfire issue). I got a D.I from a salvage yard and they did the same thing to some more brand new platty plugs. It is throwing random misfire codes. p0300 p1300.
I figured that the salvage d.i was no good so i am going to give it another try since i finally got reinburst for the part this week.
I guess the question is, has anybody had the same issue before with my symptoms ?
Or has anybody been down this road with another root cause?
I figure it's the d.i for sure but i haven't found a known good one yet. I'm getting another this week off a car with lower miles.
thanks again.
Sev7n007 is offline
Old 10-08-2009, 09:34 PM   #2
Moreboost's Avatar
What spark plugs are you using? Should be BCPR6ES-11 if I'm not mistaken. If you're using the right plugs i say try out a new/different DIC then the ones you have been trying
Moreboost is offline
Old 10-09-2009, 07:41 AM   #3
132417SAAB's Avatar
the only plugs you can use are the saab recomended ones because their used to detect knock! Black soot thought usually means over fuelling in which case I would investigate the maf and not boost the car at all! Normally a bad maf would cause lean conditions but you never know with t7
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 10-09-2009, 08:54 AM   #4
liketheword's Avatar
I ALWAYS user NGK R plugs. As that is the Saab/GS recommended use. For info see GS website on what's what with regard to Saab plugs: http://www.genuinesaab.com/psi/files/sparkplugsdi.htm
Vitamin SAAB
liketheword is offline
Old 10-09-2009, 02:24 PM   #5
Sev7n007's Avatar
Thanks guys
I got a spare Maf, from some unwanted known good parts i got, i'll try that.
I do know that i did not use ngk to replace my plugs with upon both times right before the initial issue started. (that's a good look out on that)
I'll swap out the maf and try it with the proper plugs. I am debating now whether or not i should wait on another d.i to try and see if the maf swap was the route cause. Although i don't have no codes.
yeah i was figureing ( black soot) was just lack of ignition. but i was wondering for what reason.).
Sev7n007 is offline
Old 10-09-2009, 02:44 PM   #6
Moreboost's Avatar
You should change the plugs regardless, then swap in the maf and see what happens
Old 10-11-2009, 09:28 AM   #7
Sev7n007's Avatar
thanks i'm going to try that. ( swap in the maf and change the plugs)
I really hope it's as simple as the proper plugs, and if that's the case i learned something new about the way saab does stuff. Thanks again guys i'll let you know what ha[[ens although i think i might want to wait for another d. i first cause i'm going through plugs like crazy. When i pull the ( black soot ones) plugs i couldn't imagine useing them. they just look like they are at the brinnk of being fouled up.
Sev7n007 is offline
Old 10-16-2009, 04:18 PM   #8
Sev7n007's Avatar
Plugs, D.I.....
Well i got another D.I cassette today and put in ngk iridium plugs. Unfortunatly I have the same result at first start up it seemed ok but after haveing to power the vehicle in order to hold a idle without stalling. I have come to the conclusion that i am still at square one.
Does anyone know whether or not the plugs i listed above are proper for my vehicle? I have a another air flow meter that i am going to swap in tomorrow but i fear i might just get the same results just cause i have noo such codes that lead me there.
I'm going inot more trouble shooting starting with the D.I input harness just to see if the voltages there are correct. But other than that the only ideas i got is maybe a clogged cat or maybe in take. stifling the system from air. (or not letting exhaust out)
This is the second D.I now and i'm starting to think maybe it's not the obvious.
If anyone has anymore ideas on tracking down the troubled componant please tell.
Sev7n007 is offline
Old 10-16-2009, 04:33 PM   #9
Legit's Avatar
NGK BCPR7ES gapped to 1.0mm. They are $3ea/ at Napa auto
2002 Viggen Convertible
Legit is offline
Old 10-16-2009, 07:01 PM   #10
Sev7n007's Avatar
Question thanks
the 30 bucks for 4 plugs really suck . i think i just fouled out the 30 buck ones too. I pull them out tomorrow and continue .......
Sev7n007 is offline
Old 10-17-2009, 07:04 AM   #11
I know the DI will start missing at high boost. These are non stock boost levels so on the average car the DI will seem good, but when you put it on a tuned or even MBCed car the DI will mis. I have a ton of those but they will still start the car and run it at normal boost levels.
Old 10-17-2009, 07:23 AM   #12
Sev7n007's Avatar
Unhappy well
The only mods i have done to my vehicle is a tdo4h swap and that's all pretty much the vehicle is bone stock. I can't get the vehicle to hold a idle without stalling, it's missing so bad.
Sev7n007 is offline
Old 10-17-2009, 10:40 AM   #13
Moreboost's Avatar
You sure you dont have a leak some where? Check the IC piping, sounds like that the problem or something similar.
Old 10-17-2009, 03:06 PM   #14
Sev7n007's Avatar
Talking Thanks guys
I tracked it down to the maf and the d.i. It is hitting all day now ( no misses).
Thanks for everyone's help. kinda felt like i was running in circles. I'm also glad my 30 dollar plugs where not fouled out too. Good looking out ngk iridiums.
Although the work isnot totally done I have anotherissue that came up but i'm going to start a new thread for that.
Sev7n007 is offline
Old 10-17-2009, 04:42 PM   #15
Moreboost's Avatar
You know those plugs aren't the right ones
Old 10-17-2009, 07:31 PM   #16
Sev7n007's Avatar
Red face I think you might be right about that......
Yeah i believe the iridiums are capatible with the turbo vehicles that take the 6 series. The 7 is for high load (colder tolerences and hotter).
Do you recommend that i use the specific one stated in the charts cause i have no problem buying 3 dollar ones over the 7 dollar ones i just purchased. I mean what's right is right. I know they are resistor and top of the line ngk. On the genuine saab site it talks how the 7 series can be a alternative to the more specific based 6.
Sev7n007 is offline
Old 10-17-2009, 07:34 PM   #17
Moreboost's Avatar
Human Verification
