Service Theft Alarm. Alarm constantly going off. - The Saab Link Forums
Go Back   The Saab Link Forums > Saab 9-5 98-09 Forum > Car Problems? 9-5 Only
Old 08-20-2006, 04:45 PM   #1
Chapel's Avatar
Send a message via ICQ to Chapel Send a message via AIM to Chapel
So, recently I've been getting 'Service Theft Alarm' warnings on the SID and even MORE recently, the alarm has been going off constantly.
I've had it go off right in front of me and hitting buttons on the fob does nothing.
There's no fuse to pull to make it stop and I can guarantee I'm going to get a citation from my apartment complex for disturbing the peace at night.
I think if I don't arm it or lock the car, it won't go off, but that's no way to go.
HELP!
1995 Audi S6
Chapel is offline
Old 08-20-2006, 04:59 PM   #2
Johnz826's Avatar
Send a message via AIM to Johnz826
You could disconnect the battery at night till u take it to the dealer ship to have it fixed, It may be a pain to keep doin that everynight but that's the only thing i can think of.
SAAB like no other!!!
status: Engine died, car sold
Johnz826 is offline
Old 08-20-2006, 05:01 PM   #3
StX221's Avatar
try this. next time you go to get out of the car, shut it off and take out the key. then hold the night panel button and change the setting.
see if that makes a difference.
Time for a comeback tour?
http://www.nesaab.org/forum
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 08-20-2006, 05:10 PM   #4
stromer's Avatar
When that message came up on my SID the batteries inside the siren had to be replaced. Trouble is the dealer said that the entire siren had to be replaced. It was covered under certification for me though so it wasn't such a big deal.
I'm not sure if the message can mean other components in the alarm need to be checked.
2 Saabs, 3 Chevrolets and a Suzuki.
stromer is offline
Old 08-20-2006, 05:10 PM   #5
BurnsSide42's Avatar
Garage
You need a battery for the alarm system - which is the siren/battery in the drivers wheel well area - it's not a hard fix, but a common one for a 9-5
by TSL
Contact me on Foundourownroad.com thanks!
BurnsSide42 is offline
Old 08-20-2006, 05:51 PM   #6
DriverEd's Avatar
Here's a DIY guide for the battery replacement. I'm also going to do this soon, but mine's not going sounding that often so I'm putting it off.
http://home.datacomm.ch/saeuberli/fi..._batteries.pdf
Ed
2000 Saab 9-5 Wagon LPT
2004 Mazda 3 Sport GT
DriverEd is offline
Old 08-21-2006, 04:17 AM   #7
Chapel's Avatar
any way to disable the alarm until I get time to do it?
1995 Audi S6
Chapel is offline
Old 08-21-2006, 09:16 AM   #8
friggin viggen's Avatar
Send a message via AIM to friggin viggen
using the night panel button with the key out i think
Stärka = NVIGR8 = To impart vigor, strength, or vitality to
6/3/06 - 224whp/285wtq
friggin viggen is offline
Old 08-21-2006, 01:28 PM   #9
Chapel's Avatar
okie. lets see
reeeeeally don't want to get a citation...
1995 Audi S6
Chapel is offline
Old 08-21-2006, 02:45 PM   #10
if you use the keyhole to lock the door it doesnt set the alarm.
Aero02 is offline
Old 08-21-2006, 05:02 PM   #11
Chapel's Avatar
Actually, tried that last night
the alarm still went off
haven't heard it today.
1995 Audi S6
Chapel is offline
Old 08-21-2006, 05:09 PM   #12
StX221's Avatar
USE THE NIGHT PANEL BUTTON WHEN YOU TAKE THE KEY OUT!
and yes i meant for caps lock.
that will shut off the alarm!
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 12-29-2007, 02:31 PM   #13
I am having the same problem where the alarm goes off randomly and hitting the key fob does not turn it off. I don't understand what this night panel button do in regard to the alarm? Can you please provide more specifics on what can be done?
dotnetman is offline
Old 12-29-2007, 02:37 PM   #14
StX221's Avatar
Wow. you are making me think now. I think if I remember right, take the key out, then hold the night panel button and it will allow you to change a couple things for the alarm settings.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 12-30-2007, 10:19 AM   #15
I am a little confused on how the alarm system works. The 9-5 SE manual implies that the alarm system works without the main 12v battery. Thus if a thief disconnects the battery, the alarm is still active.
So confusion #1 is that a couple of people on this forum have suggested simply disconnecting the main battery will stop the alarm.
Confusion #2 is what would cause the alarm to go off on its own if the alarm lithium batteries (Sanyo CR17335) are weak and need to be replaced? You would think with all the OBD2 codes and SID panel reporting that low alarm batteries would be a reportable item.
Old 12-30-2007, 12:35 PM   #16
jssaab's Avatar
COnfusiton #1, no it will not stop the alarm
Confusion #2. When the alarm batteries are low, you will often get service theft alarm on the SID. It will not differentiate whether it is the batteries or another issue. To be sure you will need a TECH II to diagnose. So some people change the batteries when they get the SID notifiaciton and still have an issue. That is becsuae it prolly was not the Batteries in the first place.
Best bet is to check with a TECH II to make sure weak bateries are the problem ( but it is such an easy fix, most people will just try it sans techII diagnosis.)
TEh random alarm issue coems from the weak batteries since the sytem detech a reset as the voltage drops ( not often at night as it gets cooler)
jssaab is offline
Old 12-30-2007, 01:13 PM   #17
Thank you for the clarification. For what it is worth, in my case I have not seen any display on the SID in regard to the alarm. What I have seen (or heard) is an occasional sounding of the alarm for a few seconds as it simply sits in my driveway. However yesterday the alarm went off for real (loud and persistent). The alarm did not seem to stop when I unlocked the doors. This happened twice in close chronological sequence. That was when I disconnected the battery and also unlocked my doors and left it unlocked overnight.
Also what is a TECH II? I assume this is some sort of ODB2 device that the dealer would have?
Old 01-01-2008, 06:07 AM   #18
jssaab's Avatar
Yes the TECH II Does OBDII Reading and a lot more. It connects to SAAB OBD and controls. It can change adjustments like having doors lock automatically at 7 mph , number of beeps from the alam when locking doors, program new keys and so on...
Yes it sounds like batteries in the alarm unit. Take tit out, solder in new batteries and you should be good to go. You could take it to the dealer and have them Diagnose the Alarm and see what they say. If it tells them Batteries are weak they will tell you to repalce the unit, pay them for the tech II time - my dealer does not ussually make me pay, take it home and repalce the battteries. Make sure they tell uyou what it says it will say weak alarm batteis but they might not tell you since they are "not" replacable...
jssaab is offline
Old 01-03-2008, 01:27 PM   #19
Kad
i did replace batteries but it did not help , alarm go of anyway like once a day for 2-3 seconds, and my remote control stop working to!!!!
Kad is offline
Old 01-03-2008, 01:45 PM   #20
jssaab's Avatar
So, you rplaced the batteries in the speaker box? There may be another fault in the wiring or something, you might be able to get it diagnised with a tech ii to see if there is another fault.
SOem people find that after replacing batteries they did not have enough power ( old batteries off the shelf) to work correctly. Did you check the voltage and current of the "new" batteries.
jssaab is offline
You may not post new threads
You may not post replies
Powered by vBulletin® Copyright ©2000 - 2013, vBulletin Solutions, Inc.
