The Saab Link Forums - View Single Post - Tboy's EPIC 9-5 Oil Pressure Thread
Old 05-19-2017, 10:19 AM   #10
Tboy
Shop Gauge Install and Results
So last night I put the glowshift banjo adapter in place of the stock banjo and installed the gauge.
Here is the banjo installed without the gauge. Remember this is 18 ft-lbs max torque. Don't want this breaking under expansion and contraction.
And
I had the downpipe off, but there is plenty of room to do this from below after you remove the oil filter.
Here is the gauge line, remember this is a temporary setup for a shop gauge. I don't know how long this rubber hose would hold up over time.
Results: In a word awesome. Confirmed the motor is not bad.
I get about 16-18 psi at idle once fully warm
38 psi at 2000 RPM after a 50 min highway drive. I am just above factory spec (which is 36) but I am way ahead of the 10 psi per 1000 RPM general guide.
I should note that this is with 15-50 oil, it is all I had on the shelf and I bought it really cheap last year. It is fully syn Mobil oil though.
Last edited by Tboy; 05-19-2017 at 01:56 PM. Reason: Updated "after" pressure readings and added pics
Tboy is offline   Reply With Quote
